clock in the dash
Old Feb 11, 2008 | 02:13 AM
94vtirozguy's Avatar
Default clock in the dash
have a weird issue which has just started.
The clock in the dash, the minutes continually scroll, like the time is being adjusted
when in fact it is not.
This is random, has anyone come across this before?
I am thinking it might be a dry solder joint in the electronics of the display.
Old Feb 11, 2008 | 05:00 AM
vlang29's Avatar
Default Re: clock in the dash (94vtirozguy)
I bet is in the switch that is used to adjust the time.. the contacts for the minute set are stuck closed.
I have never had one apart before, but it is screwed to the smoke colored lens that goes over the fuel, temp, lights and clock. Pull it out and take it apart and if you can see if anything can be fixed in it, but you'll probably have to replace it.
Old Feb 11, 2008 | 07:50 AM
Jagan'92's Avatar
mine started doing that a whule back, plus it flickers bright and soft when my lights are on. just a loose connection I imagine - so I haven't worried about it - but if you fix yours, I'd like to hear how.
Old Feb 12, 2008 | 12:18 AM
i will see how it goes.........
DanGAvery
Lighting
May 28, 2014 01:56 PM
vartok
May 20, 2014 04:28 AM
NIKLASAL
Sep 7, 2011 04:44 PM
VTECtravler
13
Oct 4, 2006 07:51 AM
