2000 sh with a 97 base engine
Old Mar 16, 2008 | 12:35 PM
richjr's Avatar
Default 2000 sh with a 97 base engine
ok so i have a 2000 sh lude with a bad motor. i am in the process of rebuilding a 97 base h22 motor and planning on swaping it into the sh. the base motor originally came out of a eg civic of mine but i never had the time to get it running. as far as i know the base motor has an obd1 dizzy and i have a chipped p28 ecu i am planning to use. Im going to be using the engine harness off of the sh and using it on the base engine. i also noticed that there is a resistor box for the injectors in the civic. im planning on buying a obd2 to obd1 jumper harness to use with the p28 ecu. Ive read alot about this subject but i am alittle confussed still. can anyone help me with some steps i can follow for doing this swap like what kind of wiring changes i have to make? thank you!
Old Mar 16, 2008 | 01:00 PM
97BB6Type-SH's Avatar
Default Re: 2000 sh with a 97 base engine (richjr)
The base motor will not bolt on to SH tranny. so unless u have a base tranny and base axles and intermediate shaft to swap on to your SH, then the swap wil not work.
Old Mar 16, 2008 | 01:03 PM
richjr's Avatar
Default Re: 2000 sh with a 97 base engine (97BB6Type-SH)
yea soory i forgot to mention that i do have a base tranny and axles
Old Mar 16, 2008 | 01:21 PM
vlang29's Avatar
you'll need the resistor box with obdI injectors
Old Mar 16, 2008 | 01:24 PM
vlang29's Avatar
Default Re: 2000 sh with a 97 base engine (vlang29)
this thread may also be helpful. there is a lot of useful info in the prelude FAQ
https://honda-tech.com/zerothread?id=1053816
Old Mar 16, 2008 | 01:25 PM
richjr's Avatar
^ ok will i have to change the injector clips on my engine harness?
Old Mar 16, 2008 | 01:43 PM
vlang29's Avatar
haven't found any info on the clips... i was thinking that thread i offered was exactly what you were doing, but i missed the part about you using a p28.. + +honda tech = haha.. sorry.. but there is a lot of good info.. another that may help https://honda-tech.com/zerothread?id=2226177
Old Mar 16, 2008 | 11:09 PM
gstrudler's Avatar
Someone correct me if I'm wrong, but you may to do some modifying to the '00 engine harness as I believe the '97 and '00 wiring is a little different; I'd have to go check my Helm's ETM, but I believe there were some small changes. If you have the harness for the '97, you may have better luck with it. I don't know, I might be totally whack on this, but just something to consider.
Old Mar 19, 2008 | 02:32 PM
richjr's Avatar
Default Re: 2000 sh with a 97 base engine (gstrudler)
you think i should run the motor obd1 or just get a different ecu and run it obd2?
Simon Tibbett
Dec 21, 2009 05:21 AM
_cxhatch_
Jun 12, 2007 10:00 PM
kamciu80
May 15, 2007 07:29 PM
tuan...
Oct 23, 2003 07:44 PM
eternal21
Nov 4, 2001 07:58 PM
