piston install help
Old Mar 23, 2008 | 11:32 AM
ashb82's Avatar
Default piston install help
i want to put new rings in my h22 i just dont know how to hone it. i have called all the local machine shops and they dont want to touch the frm. i just need to deglaze the walls no resize. what do you guys think i should do. i have a machine shop just dont have a honing machine. i have a milling machine that has 45 to 50 rpms so could run the correct rpms as the prelude manual says to do. i was thinking of buying one of these and pulling the stones off of it then dipping them in a real strong glue or liquid nail so the metal will not touch the frm. let that dry for a day then coat the cylinder walls with 600 grit lapping compound and run it at 45 rpm for a couple strokes.
Old Mar 23, 2008 | 09:23 PM
98vtec's Avatar
moderator emeritus
Default Re: piston install help (ashb82)
contact user DonF
Aradin
Engine Machining & Assembly
Jul 20, 2015 12:41 AM
PrettyFastRide
Aug 24, 2006 10:24 PM
drjondurst
May 20, 2003 09:12 PM
snake01
Nov 26, 2002 06:49 PM
