please help no spark
Old Mar 18, 2008 | 03:54 PM
garyslude's Avatar
Default please help no spark
hey im new well it started about 1 week ago i was drivin to work, all of a sudden my car would just die my tach would go 0 then it would start again so first i change the main relay then it would still die so then i change the fuel filter still does it then i change the ignition switch now it does not have any spark at all oh yea its a 1992 honda prelude si with a jdm h22a thanx please help!!!
Old Mar 18, 2008 | 04:08 PM
socialistic's Avatar
If it seemed like it was misfiring...shutting off and turning back on while you were driving almost too fast to notice anymore than it "burping"...sometimes dying at idle...and then not starting at all...
Replace the coil. I had the same exact problems on several of my Hondas, and replacing the coil fixed it. Also check to make sure you didn't break any plugs/wires behind the cap...and make sure everything is plugged in correctly. Check for continuity between the distributor housing and ignition module body...to be 100% sure it's grounding properly.
Old Mar 18, 2008 | 04:52 PM
garyslude's Avatar
Default Re: (socialistic)
thanxs for the reply i changed the ignition coil twice already i went and bought one about 3 hours ago still does it i check the continuity its good i dont know what else it could be
michaelb15
Dec 6, 2012 01:42 PM
hey man
Dec 22, 2010 06:59 AM
cvc1393
Nov 3, 2009 06:14 PM
chase.vanatta
Jun 15, 2009 05:12 PM
CNSK
Jan 24, 2007 11:59 AM
