How can I clean the exhaust ports?
I was just wondering, if anyone has any suggestions on how to clean out the exhaust ports? I mean, I have the manifold off But I'm not too sure how to or what to use to clean it.
Re: How can I clean the exhaust ports? (nemesis25)
Carb cleaner if your feeling dangerous, allthough all the crap that you wash off will go into the chamber. Probally make your oil dirty a whole lot quicker.
A rag and carb cleaner mabey
Re: How can I clean the exhaust ports? (Acidcrakker)
I don't know, i wouldnt want carb cleaner in my chambers for even a few revolutions
Is it really that bad? if it is maybe the head needs gone over, make sure the risk is worth the reward
Re: How can I clean the exhaust ports? (H22Luda720)
why clean them? carbon buildup?
if their just black, their going to get that way 5 minutes after you start up your car again....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H22Luda720 »</TD></TR><TR><TD CLASS="quote">I don't know, i wouldnt want carb cleaner in my chambers for even a few revolutions
Is it really that bad? if it is maybe the head needs gone over, make sure the risk is worth the reward </TD></TR></TABLE>
Well carb cleaner will evaporate relativly quick. So but the time you put the header back on it would be evaporated but will just wash the carbon build up crap into the piston chamber.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Acidcrakker »</TD></TR><TR><TD CLASS="quote">
Well carb cleaner will evaporate relativly quick. So but the time you put the header back on it would be evaporated but will just wash the carbon build up crap into the piston chamber. </TD></TR></TABLE>
Dont want to get into a debate about the characteristics of carb cleaner in a chamber with minimal venting
either way bad things can happen
either way bad things can happen </TD></TR></TABLE>
Im not saying to go out and do this. Im saying if you want to clean the ports, you clean it with carb cleaner. Ive done it before, no issues. I wont do it again, cause its pretty pointless.
I actually have the head off at the moment to repalce a burnt/broken ex. valve. So, I just trying to do some minor cleaning cuz I can't afford a port/polish job and it looks like pretty dirty. But like I've said before Im not too sure what to use to clean it? I was thinking of using a wire brush and a shop vac.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nemesis25 »</TD></TR><TR><TD CLASS="quote">I actually have the head off at the moment to repalce a burnt/broken ex. valve. So, I just trying to do some minor cleaning cuz I can't afford a port/polish job and it looks like pretty dirty. But like I've said before Im not too sure what to use to clean it? I was thinking of using a wire brush and a shop vac. </TD></TR></TABLE>
Have you not seen the word carb cleaner said numerous times?
I wouldnt use a wire brush, It would scrap the metal. Mabey a soft pad of some sort.
Are you reffering to the EGR port caps in the intake manifold? If so, then check out this procedure for removing them & cleaning the port out properly http://www.absoluteprelude.com...15340
Supposedly helps sort out any 3000rpm hesitation issues, that so many people complain about.
