wtf really
Old Feb 19, 2011 | 12:43 PM
lostkoz's Avatar
Default wtf really
i replaced my cluth and now car is not starting.
Old Feb 19, 2011 | 01:02 PM
Targa250R's Avatar
be professional
Default Re: wtf really
Can you be any more vague?
What year/model is the car?
What exactly is it doing? "Not starting" covers a whole host of different issues. Do all of the dash lights come on when you turn the key to position II ("on")? Does the starter crank the engine when you turn the key to position III ("start")?
Old Feb 19, 2011 | 01:38 PM
lazlong's Avatar
Somebody left a connector out or pinched the harness...
Old Feb 19, 2011 | 02:07 PM
lostkoz's Avatar
i left one mount on driver side. dropped motor and pulled tranny its a 94 vtec all lights work dash to. no fuse is blow or cel code. motor turns over just sounds like no compression. wont turn over if cluth is out tried that to see. as i lowered it i watched all spots for clearance. ran before and just had head work done not to long ago. only took what needed to come off touched noithing eles.
Old Feb 19, 2011 | 03:29 PM
Targa250R's Avatar
be professional
So it just makes a flat cranking sound with no compression pulses? If so (and if you have already verified that the cams are turning and that you're getting spark), it's probably just flooded. Excess fuel in the cylinders can wash down the cylinder walls, which doesn't allow the compression rings to seal. Try flooring the throttle and cranking it for 15 seconds at a time. Cranking at WOT will shut the injectors off and allow the excess fuel to clear out. It should eventually start. Don't crank for more than about 15 seconds at a time without giving it a break or you'll risk burning out the starter.
Old Feb 19, 2011 | 03:51 PM
lostkoz's Avatar
so that i tried noithing. it compresses some what just not fully. fn car ran before tranny came out its just one thing after another with this car. still no blow fuse no cel codes. turn key dash lights come on like normal. maybe just sell this hybird set up fml.
Old Feb 19, 2011 | 04:00 PM
Targa250R's Avatar
be professional
Have you checked for spark? When you turn the key to position II, does the Check Engine light illuminate for 2 seconds and then go out, or does it stay on constantly?
Old Feb 19, 2011 | 04:06 PM
lostkoz's Avatar
yeah the light gos off.
Old Feb 19, 2011 | 06:20 PM
lazlong's Avatar
Is it getting spark?
edit: nevermind, already suggested
Old Feb 19, 2011 | 08:38 PM
sde780's Avatar
Did you plug all connectors back in the right places? My EF didn't start when I left a sensor unplugged on the I/M
Did you mess with anything fuel related? if you have spark fuel and compression then it should start
Old Feb 19, 2011 | 11:09 PM
X01Michael's Avatar
i had the same problem man. it was my grounds. check the two batter ones, the one on your thermostat and the one on the right side of the valve cover. also check your spark and fuel.
Old Feb 20, 2011 | 10:06 AM
lostkoz's Avatar
i have looked at all the wires. grounds back on tranny thermostat grounds good checking spark need to get help cant do it alone. sounds like fuel pump turns on this motor is in my integra been installed from a shop head work from a shop all ran good 180 to the wheel ran before clutch went now i dont wtf from just pulling tranny. what would be the best way for checking the spark.
Old Feb 20, 2011 | 11:24 AM
X01Michael's Avatar
pull the plug while its turning and set it against the valve cover and see if it sparks. also have you checked compression?
Old Feb 20, 2011 | 12:42 PM
lostkoz's Avatar
i just had the head rebuilt i did noithing to the head its under warranty so im not touching it. let me get help to check spark and go from there cause it not compress i almost think it will go.
Old Feb 20, 2011 | 01:29 PM
lostkoz's Avatar
pulled number 1 wire spark does jump to the block.
Old Feb 20, 2011 | 01:32 PM
prelude1897's Avatar
Things that could possibly be wrong
-Grounds
-Main Relay
-Starter
-Wires going to Starter
-Bad battery
-Bad ignition switch
Old Feb 20, 2011 | 06:04 PM
ludesi904's Avatar
i had a problem like that when i did a clutch on a cb7. it ended up bein the battery terminals...just a thought though im sure u checked that
Old Feb 21, 2011 | 04:23 AM
mherkamp's Avatar
Check plugs that go into the distributor and also the plug into the bottom of the coil. Left that one off when I did my 5spd swap and wouldn't start. Abt gave me a heart attack till i found it!
Old Feb 21, 2011 | 05:49 AM
another good valid suggestion
Old Feb 21, 2011 | 11:25 AM
lostkoz's Avatar
i've been over and over the harness to see if i pinched a wire. i even replaced the plugs cause the other one's were black as f. i'm getting spark motor turns over just this fn confusing issue.
Old Feb 21, 2011 | 07:52 PM
lazlong's Avatar
Check fuel pressure.
Old Feb 22, 2011 | 06:11 AM
godslayer's Avatar
Are you out of gas?
Old Feb 23, 2011 | 10:27 PM
lostkoz's Avatar
Originally Posted by godslayer
Are you out of gas?
really like a car needs gas.
Old Feb 25, 2011 | 09:03 AM
Wyatt79m's Avatar
So did you figure it out ? I can't think of anything that hasn't already been suggested...
Old Feb 25, 2011 | 03:43 PM
lostkoz's Avatar
not yet. new battery and plugs cap and rotor. no cel codes not blowing fuses ive been over the whole harness even tried my other ecu thinking maybe hondata lost its programing. i pulled fuel line off fuel fuel turned key on fuel comes out. wire jumps spark to the block. its gotta be a wire but **** it all looks ok the black **** that covers the wire harness looks good to not like its pinched. frustrated right now done for the day. black ops time lol dont make sense ran before i pulled tranny and replace clutch. here is another at the first point of starting it will give compression just wont keep going almost thinking of push starting it
