H22 Crankshaft
Old 03-06-2011, 11:13 AM
Default H22 Crankshaft
I have an h22a1 and im having trouble spinning my crankshaft with the gridle torqued down and when i take it off. What can cause this because i have tried everything so i need some help guys .
#1rudebwoy is offline
Old 03-06-2011, 11:17 AM
dagle's Avatar
Default Re: H22 Crankshaft
What's the setup? last time I had that problem, the mains were split straight down the block between cyl#2 and 3. This was a reputable name-brand sleeve company too.
dagle is offline
Old 03-06-2011, 11:44 AM
89x90.7
8:5:1 COMPRESSION
ILL CHECK THE MAINS AND THE BLOCK LOOKS FINE BUT I'LL CHECK THAT TOO. I HAVE TONE OF LUBE DOWN THERE AND AND IT'S STILL HARD TO SPIN AND THE MAIN CAP LOOKS OK SO ILL LET U KNOW .
Old 03-06-2011, 11:50 AM
dagle's Avatar
balance shaft setup? pretty much anything that'll spin could be the problem since they all spin together.
and is it not spinning freely ONLY when the main caps are torqued down? What about when the main caps are sitting flush but not torqued to spec yet? Might be a good idea to check for flatness on the caps as well as the girdle surface
dagle is offline
Old 03-06-2011, 12:10 PM
it doesn't spin easy periode boss and im going crazy as hell, and nah man no balance shafts at all. when i spin it i does spin but it's interferrence when i try to spin it over so the pistons can spin.
Old 03-06-2011, 12:23 PM
dagle's Avatar
lol damn.. that's a bitch.
Take the belt off, spin each pulley/gear individually and see if there's a single pulley or gear that's the cause of it. If it's the crank pulley, you probably wanna take the block apart and re-inspect/re-install everything carefully.
I don't think it applies since you're a straight H22, but did you check to see if the rotating assembly (crank/rods/pistons) clear the oil squirters? I'll take a look later at my spare block and see if anything else I can think of lol. you close to getting that car running yet? haha
dagle is offline
Old 03-06-2011, 12:44 PM
lol yeah i actually mad 418 hp but i had to take it apart again because or the rings in it. and it just block and head at the moment boss no pullys but ill check everything and yeah it clears the oil squirters but i'll try again and see .
Phvntxm94
08-29-2017 06:13 AM
mylo88
10-20-2013 08:55 AM
h24 eg
11
11-18-2012 07:22 PM
Turbo_94_Lude
05-17-2011 05:45 PM
ge_itr
01-08-2007 09:37 AM
Quick Reply: H22 Crankshaft
  • Ask a Question
Question Title:
Description:
