need help
Old Mar 31, 2011 | 08:43 AM
mooseswizzle's Avatar
Default need help
wat does the water valve assembly do on a 1995 prelude????? and can it cause overheating if it isnt working??????
Old Mar 31, 2011 | 03:17 PM
Luded93's Avatar
Default Re: need help
I am pretty sure the water valve assembly directs coolant for the heater core. The valve opens when you Move the control to heat and closes when it is set to cool air It could potentially cause overheating if it were blocked or leaking. It wouldn't be the first place I would look to solve an overheating problem.
Old Mar 31, 2011 | 05:22 PM
im just checking becuz the cable has come off and i already plan on replacing the thermostat
m335
Oct 9, 2009 03:52 PM
fastrc2
Jun 20, 2008 02:58 PM
SIBuddy
Feb 5, 2007 05:35 AM
roaddogdb
Dec 21, 2002 05:06 PM
zgrimes
Oct 18, 2001 05:36 PM
