Alternative way to fill mtf other than through the fill bolt?
Hey, I was wondering is there another way of filling manual transmission fluid for a 1997 prelude other than through the fill bolt? Thanks.
Re: Alternative way to fill mtf other than through the fill bolt?
You can do it through the speed sensor, just make sure you put the exact amount, the fill hole is on the side so that you know when its full cause it'll spill out. You could also get a funnel from the auto parts store and put a 3ft hose on it and do it from the top with the hose going down into the fill hole, will just have to remove the intake pipe.
People say you can use speed sensor but I always just use the fill bolt, it's about the same amount of work
thiscivicuser
02-26-2008 06:13 PM
