Lowered prelude and alignment
Old Feb 6, 2004 | 09:10 AM
Prelude1999's Avatar
Default lowered prelude
Alright I have a 99 Prelude and its lowered about 2 inches and I guess when they lowered my car it made the wheels turn in so the tires get worn down alot quicker. And I guess thats really common. Im not sure I dont know alot about cars so sorry if I sound a bit amatuer. Well i hear there is some kind of kit you can buy to fix it. Does anyone know whats it called and how much it costs? Thanks!
Old Feb 6, 2004 | 09:24 AM
killa_lude's Avatar
Default Re: lowered prelude (Prelude1999)
a ingalls camber kit might intrest u...
http://www.mmrusa.com/ingalls/ingallshonda.htm
you need to get a set for the front and back...
Old Feb 6, 2004 | 09:44 AM
silver97prelude's Avatar
or just have your tires turned/rotated, when the inside starts to wear on mine, i just have them turned so the outside becomes the inside but im only dropped like 1 inch.
but with 2 or more inches lower its good to get a camber kit.
Old Feb 6, 2004 | 10:33 AM
BlckBeautyVTEC's Avatar
Default Re: lowered prelude (silver97prelude)
yes its called camber its what happens when u lower or lift a car
Old Feb 6, 2004 | 12:53 PM
makavelli1227's Avatar
it is called get an alignment, get that done first,, then see if u have to get a camber kit...dont waste money on it if u dont have to.
Old Feb 13, 2004 | 05:44 PM
IVI's Avatar
IVI
Default Re: (makavelli1227)
what will too much negative camber do? besides wear out your tires?
Old Feb 13, 2004 | 07:09 PM
Cottonwoodz's Avatar
Default Re: (IVI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IVI &raquo;</TD></TR><TR><TD CLASS="quote">what will too much negative camber do? besides wear out your tires?</TD></TR></TABLE>
Make you look like a stunna...
Old Feb 13, 2004 | 07:18 PM
MugenPoweredLude's Avatar
get an alignment, youre probally most likely going to need camber kits so i suggest
SPC front and rear
Old Feb 13, 2004 | 08:13 PM
TruNinja619's Avatar
Default Re: lowered prelude (killa_lude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by killa_lude &raquo;</TD></TR><TR><TD CLASS="quote">a ingalls camber kit might intrest u...
you need to get a set for the front and back...</TD></TR></TABLE>
how do u determine which ones to buy for the front and the back....
i see 2 different kinds for the front 'n back.....
Old Feb 13, 2004 | 08:53 PM
killa_lude's Avatar
Default Re: lowered prelude (TruNinja619)
they should be the same ones actually, the part numbers are the same.
Old Feb 13, 2004 | 09:09 PM
There is 2 different kinds of kits, depending on the Degree of camber you need...
Get a alignment first to see what degree you are off..
Old Feb 13, 2004 | 09:39 PM
RAB's Avatar
RAB
Default Re: (Cottonwoodz)
if it goes straight leave it how it is.
Old Feb 14, 2004 | 05:14 AM
killa_lude's Avatar
Default Re: (RAB)
yeah cottenwoodz is right, you might want a different kit for the back or vice versa.
btw like cottonwoodz already said there are two different kinds and they can be used interchangaebly...i got 2 sets of part # 35730 these give u the most range.
Old Feb 14, 2004 | 07:39 AM
connvict's Avatar
Additionally, You may also want to save your money first, and go get your toe angle set. I have a '98 I dropped 2" as well, and my camber stayed fine, alignment stayed fine, but my tires were toed in pretty significantly. You cxan adjust your toe yourself, or take it to a shop, and they should do it for you for cheap.
Old Feb 20, 2004 | 05:39 PM
steveoh22's Avatar
Default Re: (connvict)
neg camber looks like / \ front the front . this happens when lowering a vehicle pos =\ /
540dude
Suspension & Brakes
Apr 23, 2012 02:23 AM
Trevwh0re
Suspension & Brakes
Sep 3, 2009 05:48 PM
jdmh22lude2
May 17, 2006 07:30 PM
Phillip4285
Nov 28, 2005 06:39 AM
msmith01lude
Apr 3, 2005 07:12 AM
