Boosted BB1 Stage 1 pics!
Old Mar 1, 2004 | 10:47 AM
NirVTEC's Avatar
Default Boosted BB1 Stage 1 pics!
STAGE 1: BUILDING A BULLET PROOF BOTTOM END
H22A1 block sleeved with darton Iron sleeves. The block has been line-bored, honed, decked, and has a micropolished/balanced crank. Crower Rods and CP Pistons(9:1) will be fitted into it making the block ready for at least 600whp!
Now I just need to figure out which Turbo to buy, and which EMS I will use. Hondata, AEM, and MicroTech are the contenders. Golden Eagle IM, and LOVEFAB Turbo Manifold. Is there any little "heads-up" people can give me when assembling this block? I trust my engine builder with my life, but any input would be appreciated. I plan to use OEM bearings. Head gasket suggestions? Thicker? maybe to drop the compression just shy of 9:1?
^^^^^These are not the actual pistons^^^^^
Stay tuned for Stage 2 which will be posted in a couple of weeks.
Modified by NirVTECn2o at 8:07 PM 3/1/2004
Old Mar 1, 2004 | 11:15 AM
georgiajdm's Avatar
Default Re: Boosted BB1 Stage 1 pics! (NirVTECn2o)
Those are some huge chevy/ford pistons.
Old Mar 1, 2004 | 11:31 AM
NirVTEC's Avatar
Default Re: Boosted BB1 Stage 1 pics! (georgiajdm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by georgiajdm &raquo;</TD></TR><TR><TD CLASS="quote">Those are some huge chevy/ford pistons. </TD></TR></TABLE>
They sure are..........I figured I had to disclose that they aren't actual pistons before someone felt the need to try to blast me............
CP won't let you link from their site, and my pistons are on order!
Old Mar 1, 2004 | 12:08 PM
TurboSam's Avatar
they look like ford pistons, something small bore, like a 302 maybe. most chevy stuff would have more of a dome area, although the valves reliefs are huge, and chevy typicallt uses larger valves
Old Mar 1, 2004 | 03:01 PM
spoolinlude's Avatar
I live under a rock
Default Re: Boosted BB1 Stage 1 pics! (Turbo Sam)
factory bearings???? if its line bored, check your tolerances, bet you need std size
Old Mar 1, 2004 | 03:33 PM
NirVTEC's Avatar
Standard size as in NOT METRIC?
Sean EgHatch909
Aug 15, 2012 05:11 PM
allmotaeg6
Mar 23, 2010 08:20 PM
bjfisher
Aug 2, 2006 10:25 PM
monEmakindave
Northeast (Sales)
32
Feb 16, 2006 07:58 PM
