JDM LSD
Old Feb 26, 2004 | 07:15 AM
eric416's Avatar
Default JDM LSD
does anyone know where i can buy a jdm lsd, im not looking for the whole tranny.
Old Feb 26, 2004 | 07:40 AM
satan_srv's Avatar
Default Re: JDM LSD (eric416)
you realize the 4th gen LSD only fits in an M2B4 casing..not any H tranny...
Old Feb 26, 2004 | 08:56 AM
@ries's Avatar
Why does it have to be the stock "JDM" one? What's wrong with Quaife, Cusco, or Kaaz?
Old Feb 26, 2004 | 09:53 AM
Adam.'s Avatar
It'll probably end up costing you more (time, money and effort) to get a stock JDM LSD then it would to go grab one of the above mentioned.
Old Feb 26, 2004 | 10:03 AM
georgiajdm's Avatar
Default Re: JDM LSD (emoBB1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by emoBB1 &raquo;</TD></TR><TR><TD CLASS="quote">Why does it have to be the stock "JDM" one? What's wrong with Quaife, Cusco, or Kaaz?</TD></TR></TABLE>
Cause these are like a grand. If you can find a used oem one it'll probably set you back 400-600
Old Feb 26, 2004 | 12:16 PM
KENLUDE97's Avatar
Default Re: JDM LSD (georgiajdm)
As allready mentioned it will not fit in a USDM gear case. You have to get the whole tranny if you want the JDM LSD. They have better gear ratios too that is why i went with them.
Old Feb 26, 2004 | 01:13 PM
eric416's Avatar
will Quaife, Cusco, or Kaaz fit in an h22 tranny
Old Feb 26, 2004 | 05:39 PM
supaZZZleepa's Avatar
quaife works a lot better than a jdm lsd...worth the investment
Old Feb 26, 2004 | 05:45 PM
satan_srv's Avatar
Default Re: JDM LSD (KENLUDE97)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KENLUDE97 &raquo;</TD></TR><TR><TD CLASS="quote">As allready mentioned it will not fit in a USDM gear case. You have to get the whole tranny if you want the JDM LSD. They have better gear ratios too that is why i went with them. </TD></TR></TABLE>
Where did you get that? M2B4 LSD tranny has the same gear ratios as any USDM 4th gen prelude.
Unless you mean compared to 5th gen prelude...but they're really not that much shorter...the 5th gen 2nd (1.956) is shorter than the 4th gen (1.950)
Old Feb 26, 2004 | 07:48 PM
tylek17's Avatar
i have a kaaz so much fun
Old Mar 10, 2004 | 01:08 PM
ALLMOTORJ's Avatar
Default Re: JDM LSD (satan_srv)
Will a quafie fit in a jdm m2b4 tranny?
Old Mar 10, 2004 | 01:30 PM
satan_srv's Avatar
Default Re: JDM LSD (4gotpasswordAGAIN)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4gotpasswordAGAIN &raquo;</TD></TR><TR><TD CLASS="quote">Will a quafie fit in a jdm m2b4 tranny? </TD></TR></TABLE>
Nope, not in my experience anyway, we could not fit it, it was too loose 2 shims and it still wasn't in.
Old Mar 10, 2004 | 05:26 PM
SKDRCR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by georgiajdm &raquo;</TD></TR><TR><TD CLASS="quote">
Cause these are like a grand. If you can find a used oem one it'll probably set you back 400-600</TD></TR></TABLE>
why spend 600 on a used oem one, you could get a quafie for a couple hundred
bucks more and have a better lsd with a lifetime warranty
Old Mar 10, 2004 | 06:06 PM
volklude's Avatar
stupid question, but can u get LSD in an auto tranny?
Old Mar 10, 2004 | 08:54 PM
georgiajdm's Avatar
Default Re: (volklude)
yes
Old Mar 10, 2004 | 09:17 PM
satan_srv's Avatar
yeah man the m2B4 LSD blows goats, you can't even feel it.
Old Mar 11, 2004 | 03:08 AM
Pat McGroin's Avatar
Default Re: (satan_srv)
If the Quaife doesn't fit in an M2b4 tranny, will it fit into an M2A4(non-LSD)?
Old Mar 11, 2004 | 03:43 AM
satan_srv's Avatar
Default Re: (Pat McGroin)
yes it should, and it should fit in all 97-01 trannies even with LSD like the euro-r, type-r, f20b etc.
Old Mar 11, 2004 | 04:59 AM
iakona's Avatar
so the M2Z4 doesn't have a JDM-sized differential?? i am looking to upgrade to a cusco unit and was ready to buy the RS for my M2Z4 SiR/S-spec transmission i have. now, i'm confused...
Modified by iakona at 8:11 AM 3/11/2004
Old Mar 11, 2004 | 05:15 AM
satan_srv's Avatar
Default Re: (iakona)
what's an RS?
Anyways, I don't think so...people have put quaife's in euro-r lsd's but I can't tell you for sure because I haven't done it myself
Old Mar 11, 2004 | 07:10 AM
iakona's Avatar
the RS is the Cusco LSD (along with the MZ). but if the Quaife will fit, i may get one of those instead. i was under the impression it would not because the differentials were different sizes from the US to the JDM. hence, my confusion.
Old Mar 11, 2004 | 08:52 AM
ALLMOTORJ's Avatar
what is the tranny code of 4th gen h22a trannies?
Old Mar 11, 2004 | 08:54 AM
ALLMOTORJ's Avatar
Default Re: (4gotpasswordAGAIN)
usdm of course
Old Mar 11, 2004 | 10:40 AM
NoLipRacen's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4gotpasswordAGAIN &raquo;</TD></TR><TR><TD CLASS="quote">what is the tranny code of 4th gen h22a trannies?</TD></TR></TABLE>
m2f4
Old Mar 11, 2004 | 12:03 PM
ALLMOTORJ's Avatar
Default Re: (NoLipRacen)
so I'm guessing that you can't put a quafie in a jdm non-lsd M2A4
