Problem!
Old Feb 23, 2004 | 09:17 AM
Tee Jay's Avatar
Default Problem!
So here's the story, I was driving home the other night at around 8pm or so and all of a sudden my lights on my dash cut off while having them on. So none of my parking lights work. Rear, corners, etc. The only thing that works when I turn the **** for my lights are my head lights.
I checked my fuses under the hood and my the driver side. I found one blown fuse under the hood and replaced it. Turned on my lights nothing. Checked back at that fuse and burnt. I did this for about 3 fuses and decided to quit.
What could be the problem? I'm afraid of getting pulled over at night since my rear lights don't work. Please help. TIA!
Old Feb 23, 2004 | 09:22 AM
Variable J's Avatar
Default Re: Problem! (Prelude_Si)
if your blowing fuses you probably have something going on with the wiring somewhere else. Its probably either an open circuit or wires are touching. Do you have aftermarket lights in your corners and dash?? Who did the work?? Do you have an automotive multimeter?? Electrical stuff can be difficult to work with you have to know what your doing.
prelittlelude's Avatar
well obviously you have a short somewhere, i would check you bulds out for the back and corners, you will have to do some reaseach own you own, and try and narrow down where the electrical short is. the fuse is blowing for a reason. first thing i would check is that you don't have any bulb sitting in water
Old Feb 23, 2004 | 09:26 AM
Tee Jay's Avatar
Default Re: Problem! (prelittlelude)
I have no aftermarket bulbs are anything everything is stock. But I guess I'll start checking to see if any of my bulbs are in water. I have nothing electrical done to the car besides my amp which I don't think effects any of this.
Old Feb 23, 2004 | 09:31 AM
look on the cover of the fuse box, under the hood, and see which fuse it is they ususally have a general label, and i have a helms and i will look it up and see what i can find for u
Old Feb 23, 2004 | 09:36 AM
Tee Jay's Avatar
20A - Small Light
Old Feb 23, 2004 | 10:29 AM
DW's Avatar
DW
did you recently install a stereo? if the illumination wire isnt taped up it will hit a ground and blow that fuse. might wanna check that out...
David
Old Feb 23, 2004 | 11:00 AM
Tee Jay's Avatar
Default Re: Problem! (DW)
The stereo has been in forawhile already
Old Feb 23, 2004 | 03:40 PM
DW's Avatar
DW
might want to check the connections anyways the tape may have come off or something
David
Old Feb 23, 2004 | 04:59 PM
Tee Jay's Avatar
Alrite
slammed em1
Jan 23, 2010 09:26 PM
lilshady6796
Nov 12, 2008 06:33 PM
YouGotHacked
Honda Civic (2001 - 2005)
Nov 16, 2006 09:52 PM
mel
12
Nov 9, 2006 09:04 AM
wezzel19
Jul 15, 2006 12:02 PM
