h22 dyno plot...
Old Feb 24, 2004 | 04:57 PM
aeolus's Avatar
Default h22 dyno plot...
Went to Trackmasters to have my engine dyno tuned.Sorry,this is a civic hybrid,but since it does have the heart of a prelude,i'd thought id share with my fellow h-t members....
heres a brief rundown ..
re-sleeved h22a block
eagle rods,wiseco pistons,stock h22 crank,acl bearings
crower stage 3's
mild ported head and stock manifold
64.5mm tb
DC header primaries with a remade custom secondary piping and 2.5" merge collector
2.5" exhaust and piping.
aluminum flywheel
no counter balance shafts
p28 hondata s100
all porting,assembly,planning done by yours truely
I wasnt expecting this much,we didn't tune the cam gears much because i pretty much just dropped in the cams after i built the motor.but i do have the portflow valve train though.And i would like to add,Bubba(Carlos) at Trackmasters was very helpful in letting me know what exactly he was doing while he was dyno tuning my car.I believe i learned alot during this dyno session. to Trackmasters and Bubba.
Modified by aeolus at 7:14 PM 2/26/2004
Modified by aeolus at 8:41 AM 3/2/2004
Modified by aeolus at 7:13 AM 3/24/2004
Modified by aeolus at 9:43 PM 4/10/2004
Modified by aeolus at 1:37 AM 6/6/2006
Old Feb 24, 2004 | 05:05 PM
Revi's Avatar
Default Re: h22 dyno plot... (aeolus)
X my friend.
What were the numbers anyways?
Old Feb 24, 2004 | 05:08 PM
biglew's Avatar
Nice numbers, what's your compression ratio? Are you running sleeves?
Old Feb 24, 2004 | 05:09 PM
Soda Popinski's Avatar
Default Re: (biglew)
Nice numbers even with a crappy dc sports header.
Looks like the stokc manifold and the header could free up some more ponies.
Old Feb 24, 2004 | 05:15 PM
@ries's Avatar
Good job How many runs did they do and what's the fuel set up(injectors, fuel pump, fuel pressure reg.) Torque seems a wee bit low but thats probably due to the header... just my .02
Old Feb 24, 2004 | 05:29 PM
aeolus's Avatar
Default Re: h22 dyno plot... (emoBB1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by emoBB1 &raquo;</TD></TR><TR><TD CLASS="quote">Good job How many runs did they do and what's the fuel set up(injectors, fuel pump, fuel pressure reg.) Torque seems a wee bit low but thats probably due to the header... just my .02</TD></TR></TABLE>
We did four runs i believe. im using rc 440's with a walbro 190 lph fp and a b@m fpr.Yes,the block is re-sleeved.
Old Feb 24, 2004 | 05:34 PM
@ries's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aeolus &raquo;</TD></TR><TR><TD CLASS="quote">
We did four runs i believe. im using rc 440's with a walbro 190 lph fp and a b@m fpr.</TD></TR></TABLE> I think they could've done more runs...but then again they made pretty good power for only doing 4 runs. Are you planning on going back to get your cam gears tuned? Oh yeah...is the cat. still on?
Old Feb 24, 2004 | 05:41 PM
biglew's Avatar
Default Re: (BeeBeeOne)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BeeBeeOne &raquo;</TD></TR><TR><TD CLASS="quote">Nice numbers even with a crappy dc sports header.
Looks like the stokc manifold and the header could free up some more ponies. </TD></TR></TABLE>Not likely since the DC header has a modified collector.
Old Feb 24, 2004 | 05:43 PM
Yes, but the primaries are still small and dinky. Im sure with a smsp header he would gain more through out the power band, or a header with better design like header-techs, or 10-94s header. Or maybe heck even A&R.
Old Feb 24, 2004 | 05:48 PM
aeolus's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by emoBB1 &raquo;</TD></TR><TR><TD CLASS="quote"> I think they could've done more runs...but then again they made pretty good power for only doing 4 runs. Are you planning on going back to get your cam gears tuned? Oh yeah...is the cat. still on?
maybe,i have a feeling i may not have enough room to adjust because of the cams.i didnt want to sacrifice the engine for just a few more ponies.Plus,i was there for an hour at the most.My main concer was to get the a/f ratio correct because i was runnin on this base map since october.Even though there isnt a high hp gain,the engine runs smoother and uses less gas now.And also,along with the four hard dyno pulls to redline,we did a cruise run to just to get part throttle running well.And nope,test pipe.
Old Feb 24, 2004 | 05:54 PM
biglew's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BeeBeeOne &raquo;</TD></TR><TR><TD CLASS="quote">Yes, but the primaries are still small and dinky. Im sure with a smsp header he would gain more through out the power band, or a header with better design like header-techs, or 10-94s header. Or maybe heck even A&R.</TD></TR></TABLE>Well I think there isn't much question about the SMSP header being superior, but I thought the DC header primaries were almost the exact same size as the stock mani.
Old Feb 24, 2004 | 05:57 PM
aeolus's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by biglew &raquo;</TD></TR><TR><TD CLASS="quote">Well I think there isn't much question about the SMSP header being superior, but I thought the DC header primaries were almost the exact same size as the stock mani.</TD></TR></TABLE>
the dc primaries are bigger than the stock ones,at least the stock jdm h22a i had.Bubba did recommend possibly a better manifold and headers will help alot.
Old Feb 24, 2004 | 06:00 PM
H22ek4's Avatar
Default Re: (aeolus)
whats the compression? nice numbers
Old Feb 24, 2004 | 06:06 PM
aeolus's Avatar
Default Re: (H22ek4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H22ek4 &raquo;</TD></TR><TR><TD CLASS="quote">whats the compression? nice numbers </TD></TR></TABLE>
im gonna guess around 11.5 to 11.8 or so.
Old Feb 24, 2004 | 06:15 PM
Daboi630's Avatar
make sure you get this dyno in my sig too
Old Feb 24, 2004 | 06:17 PM
biglew's Avatar
the dc primaries are bigger than the stock ones,at least the stock jdm h22a i had.Bubba did recommend possibly a better manifold and headers will help alot.</TD></TR></TABLE>Well I stand corrected then. Also are you running iron sleeves with those wisecos?
Old Feb 24, 2004 | 07:44 PM
aeolus's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by biglew &raquo;</TD></TR><TR><TD CLASS="quote">Well I stand corrected then. Also are you running iron sleeves with those wisecos?</TD></TR></TABLE>
yes,i am running iron sleeves.
Old Feb 24, 2004 | 07:47 PM
satan_srv's Avatar
i can't see the pic...what are the numbers?
I have crower stage 3 as well, I left them at 0/0 I really can't spare the room to mess with them
Old Feb 24, 2004 | 07:49 PM
Default Re: (satan_srv)
He made 215 whp and 159whtq i think. Not bad for a dc sports/2,5inch collectored header, and stock manifold. and wiht 11:5 tp 11:8 compression.
Old Feb 24, 2004 | 07:50 PM
Daboi630's Avatar
silly goes. its right th...... oh **** what happend to the pic.
it was 217ish i think with 157ish torque. dont get mad if my memory sucks
edit: you beat me too it. glad my memory isnt that far off
Old Feb 24, 2004 | 08:00 PM
satan_srv's Avatar
Default Re: (Daboi630)
yay I make more torque...I'm running a high flow cat though...
is this with a test pipe/no cat?
Old Feb 24, 2004 | 08:20 PM
Mr.Squeeze's Avatar
Yes he said with a test pipe.
Daboi630's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by emoBB1 &raquo;</TD></TR><TR><TD CLASS="quote">Oh yeah...is the cat. still on?
And nope,test pipe.</TD></TR></TABLE>
there you go boss
edit: damn my slow typing!!
Old Feb 24, 2004 | 08:23 PM
Default Re: h22 dyno plot... (Daboi630)
Yea dude You type like a bitch.
Old Feb 24, 2004 | 08:24 PM
Daboi630's Avatar
hahahah
i hate you....
