Need help with engine...engine Revs back and forth...
Old Feb 22, 2004 | 10:40 PM
koiz's Avatar
Default Need help with engine...engine Revs back and forth...
have 92 honda prelude si manuel...
after starting up the engine cold the engine revs back and forth....
around 1500 RPM to 3k until the engine warms up then it stops....
can someone tell me whats wrong..??
Old Feb 22, 2004 | 10:58 PM
@ries's Avatar
Default Re: Need help with engine...engine Revs back and forth... (koiz)
Vacuum leak or the IAC or fast idle valve/solenoid might have gone bad.
Old Feb 22, 2004 | 11:23 PM
diluted's Avatar
I had the same problem a while back. I'd proably look into adjusting the screw on the fast idle thermo valve. It's underneath the throttle body, i think theres three screws that hold it on. just unscrew those, then i think you pull it apart, then theres this white plastic screw thing, take an oversized flat tip screw driver or something that can turn it, tighten it down to where it sorta stops i think. refer to a helm's for more detailed instructions.
Old Feb 23, 2004 | 11:39 AM
koiz's Avatar
Default Re: Need help with engine...engine Revs back and forth... (diluted)
thanks... thought it was going to be a bigger problem...
meanshyguy
Oct 24, 2007 12:49 PM
KanDaMan
Mar 26, 2007 11:28 AM
Cowboy
Mar 5, 2004 12:08 PM
prdtr15
Aug 24, 2003 06:36 PM
Rah Rah
Jan 30, 2002 09:27 PM
