balancer/auto ten missing? Pic inside?
went to change the alternator belt and the guy helping me said i was missing a part? what is is and is there any effects to not having it?
Re: (KTeller8)
You're missing the valve cover. Seriously I don't think anyone would be able to tell if you were missing the auto tensioner just by taking off the valve cover.
Re: (RAB)
maybe i didnt ask it correctly, it has nothing to do with the valve cover missing lol
ok
on my alternator, i see a hole,, and nothing under it, local guy said i was missing the auto ten there.. is there anything that bolts on to the alternator? that was the only picture of the alternator i had
why i listed alternator in the first post
ok
Do you see a pretty loong bolt that runs through the alternator attached to a bracket? That bolt adjust the tension in your alternator belt and that's what i'm thinking the guy was telling you
ill see if i can get a pic of it later for you
Re: (EGPrelude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EGPrelude »</TD></TR><TR><TD CLASS="quote">damn i just went outside and its cold and DARK so i couldnt get a good pic
ill see if i can get one tomorow</TD></TR></TABLE>
that must be it, cause all i got is a hole where the bolt would go
is there any thing with not having it ?
Re: (satan_srv)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by satan_srv »</TD></TR><TR><TD CLASS="quote">Do you mean the A/C Compressor? Usually it goes right under the alternator.
Or if it's really part of the alternator maybe this will help
I bet he is talking about #10
Guest
Posts: n/a
Re: (Revi-Ra)
hey bro i know what your talking about and you dont need it! just have a friend pull it tight while you tighten it down! that what i did and it works fine! its not a auto tensioner its just a screw you can tighten instead of trying to pull it tight!
Re: (spanishlude)
it might be #10, not sure:
But it is the two bolt little thing under the alternator, i went out and looked today at a car in the parking lot: Kid showed me, it has two bolts, i guess its used to help tighten the alterator belt
imadigitalgod
17
09-07-2009 01:51 PM
