rotor question
Old Mar 18, 2004 | 01:54 PM
volklude's Avatar
Default rotor question
hey guys, im buying new rotors, and i have decided to go with the brembo slotted and cross drilled rotors. i was 1 step away from ordering them from evasive motorsports but they only have them for 92-96 preludes Vtec....i have an 92 Si that used to have an h23 in it, soo is there a difference? the lug pattern is the same and all, i dont know what would be different. please help!! haha
thanks guys!
James
Old Mar 18, 2004 | 01:59 PM
NoLipRacen's Avatar
Default Re: rotor question (volklude)
the vtecs came with a large rotor i think it was 11.1" S and Si came with the smaller ones. if you bought those you will need to do the conversion, unfortunately i dont remember what all is involved. and watch out those cross drilled rotors are prone to cracking...
Old Mar 18, 2004 | 04:36 PM
h22mark's Avatar
Default Re: rotor question (NoLipRacen)
Yeah the cross drilled are prone to cracking, and stupid purchased them before I researched . But its ok they go in the back, not that much of a problem if they were in the front.
Old Mar 18, 2004 | 07:35 PM
98 blacksh's Avatar
Default Re: rotor question (h22mark)
i have had brembo slotted and cross drilled on my front for a while and nothing but good comments
Old Mar 18, 2004 | 07:51 PM
spnbb2
Guest
Posts: n/a
you can buy the vtec rotors but your going to need vtec brackets also...you can still use the si caliper though
Old Mar 19, 2004 | 06:50 AM
volklude's Avatar
Default Re: (Ludinitup)
yeah i got it under control, i contacted evasive motorsports and the guy said he had a set of Si slotted and cross drilled rotors in stock. worked out very nicly. thanks for the help!
Motionek55
10
Sep 8, 2012 02:04 PM
1994PreludeSi
Oct 19, 2007 10:51 PM
4doorex
22
Jan 22, 2004 06:53 AM
riceball777
Jul 22, 2003 03:49 PM
jason_alt
Apr 22, 2003 10:42 AM
