Replacing corner front corner light!
Old Mar 16, 2004 | 07:02 PM
motegiracersi's Avatar
Default Replacing corner front corner light!
How do I replace my corner light, do I have to take out the whole headlight?
Old Mar 16, 2004 | 07:08 PM
AndyD's Avatar
Default Re: Replacing corner front corner light! (motegiracersi)
https://honda-tech.com/zerothread?id=791311
Old Mar 16, 2004 | 08:51 PM
stupidfox's Avatar
if its a fourth gen theres a screw inside a teardrop hole like on top of your headlight that bell shaped on top? (sorry bout all the technical terms lol) but yeah, you take that out and the corner light kida twists out. I put amber ones on my 94 and yeah- putting it back in is the annoying part!
and when you're putting that back together, the only way that worked for me was to unclip the bulb holder from the wire, twist it into the corner light, then clip the back together as you put it back in. if the wires were just a little longer!
Modified by thestonerhimself at 11:15 PM 3/17/2004
Modified by thestonerhimself at 3:18 AM 3/19/2004
Old Mar 16, 2004 | 10:12 PM
TruNinja619's Avatar
Default Re: Replacing corner front corner light! (jz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jz &raquo;</TD></TR><TR><TD CLASS="quote">what year? if its a 4th gen all you have to do is unscrew one screw and thats it. you should be able to see it when looking at it. then pull the corner light out slitghtly hard cause its in there.</TD></TR></TABLE>
2 screws...... i learned the hard way when i tried ripping the damn thang.....
Old Mar 16, 2004 | 10:31 PM
VTECRaZeR's Avatar
Default Re: Replacing corner front corner light! (TruNinja619)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TruNinja619 &raquo;</TD></TR><TR><TD CLASS="quote">
2 screws...... i learned the hard way when i tried ripping the damn thang..... </TD></TR></TABLE>
True that, I was getting ready to rip the damn thing apart when me and my friend figured out that there were 2 screws.
Talking about corner lights, I've always wondered how do you get in there in the JDM 1 piece headlights....any1?
Old Mar 17, 2004 | 05:27 AM
AndyD's Avatar
I just changed mine on my 92 Si. There is only one screw. I am POSITIVE!!! Just how jz described it.
Old Mar 17, 2004 | 07:41 AM
SKDRCR's Avatar
Default Re: Replacing corner front corner light! (AndyD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AndyD &raquo;</TD></TR><TR><TD CLASS="quote">I just changed mine on my 92 Si. There is only one screw. I am POSITIVE!!! Just how jz described it.</TD></TR></TABLE>
<FONT COLOR="green"> wurd, there is a hole in your upper radiator support
where the screw is </FONT>
Kendo88
Oct 25, 2008 11:33 PM
06siracer
Honda Civic (2006 - 2015)
May 21, 2008 12:35 PM
DOHC_C-REX
15
Oct 5, 2005 10:01 AM
animated_life
Dec 27, 2003 12:03 PM
niteboyzzz
May 12, 2003 01:49 PM
