need intake help
Old Mar 24, 2004 | 02:51 PM
cbmprelude's Avatar
* B A N N E D *
Default need intake help
I installed my home made intake on my 5th gen prelude. I removed the stock resonator and also the little vacum box. I tied a knot in the line leading to the front of the intake manifold from the resonator. I noticed now a nipple sticking up from my manual trans. what is this nipple for? Also there is a little box behind my right front turnsignal what is this box?
Old Mar 24, 2004 | 03:16 PM
95ONE's Avatar
Default Re: need intake help (cbmprelude)
If you're talking about the one in the front fender well, it has a butterfly also. Helps torque. Throw it out. Tied a knot!? Just stick a vacum plug on the line. it's cleaner.
Old Mar 24, 2004 | 03:53 PM
Kal's Avatar
Kal
Default Re: need intake help (nsxlr8)
the rubber nipple thing on the tranny is the to look at the alignment marks on the flywheel.
edit: i was being dumb
Old Mar 24, 2004 | 10:08 PM
cbmprelude's Avatar
* B A N N E D *
Default Re: need intake help (Kal)
So then the nipple is supposed to be there and be uncovered? Also the little black box is what? It isn't connected to the resonator.
Old Mar 24, 2004 | 11:22 PM
Matgallis's Avatar
I think he's talking about that metal tube thing sticking out of the tranny. I believe if helps it breath or something like that...
Old Mar 25, 2004 | 07:10 AM
cbmprelude's Avatar
* B A N N E D *
Default Re: need intake help (Matgallis)
It isn't supposed to be connected to anything right? And also what is that black box up there?
Old Mar 25, 2004 | 07:45 AM
UA6 BALLER STATUS's Avatar
Im not sure what you guys are talkin about but is this it?
Old Mar 25, 2004 | 10:12 AM
cbmprelude's Avatar
* B A N N E D *
Default Re: need intake help (Type_SH)
That is exectly what I am talking bout
Old Mar 25, 2004 | 10:38 AM
Oh ok. Someone told me that there is supposed to be a rubber cover for it, but you don't really need it. Is that where you put the transmission fluid in?
Old Mar 25, 2004 | 10:49 AM
94vtecmn's Avatar
That is the transmission breather tube, not a filler inlet. It is suppose to have a little rubber cap on it to prevent dirt and foriegn particles from getting in the transmission.
Old Mar 25, 2004 | 10:52 AM
NoLipRacen's Avatar
yes its the tranny vent tube. you can fill your tranny from there but it takes 4EVAR!!! as for that little black box, maybe youre talking about the IAC?
Old Mar 25, 2004 | 11:20 AM
Default Re: need intake help (NoLipRacen)
Has anyone used anyone thing else other then the EO cap to cover it up?
Old Mar 25, 2004 | 11:31 AM
94vtecmn's Avatar
I'm pretty sure I have a small piece of a rag folded over a couple times with a rubber band on it right now.
As for filling it there, you should not, because you can over fill it. That's why the filler hole is on the side of the tranny, so when it starts to run out, its full, and you can't over fill it.
Old Mar 25, 2004 | 11:34 AM
cbmprelude's Avatar
* B A N N E D *
Default Re: need intake help (94vtecmn)
So i guess I should cover mine then. What does IAC?
horn12007
Oct 20, 2010 07:04 AM
tacticalcustoms
Oct 6, 2006 01:17 PM
driftmaster04
Aug 9, 2005 08:46 PM
Nizzy
Jul 23, 2003 02:01 AM
Nizzy
Jul 20, 2003 08:23 PM
