timing a h23
Old Mar 20, 2004 | 08:22 PM
xtreame18's Avatar
Default S.O.S. HELP ! ! ! Timing an H23
I have a 1992 prelude si with a h23. The valves went out on the car at about 4000 rpms so i had the head rebuilt and i just got it back together. The valves still are raping and I think it is the timing it is driving me nuts and I cant figure it out any links or info on how to time this car would be great I have rebuilt alot of civcs and integras but have never ran into this problem but i have also never worked on a H series motor before. dose the balance shaft have any thing to do with my taping noise? also all the noise is definetly coming from the top of the motor I have adjusted all the valves to spec.
Modified by xtreame18 at 7:03 PM 3/21/2004
Old Mar 21, 2004 | 10:17 AM
xtreame18's Avatar
Default Re: S.O.S. HELP ! ! ! Timing an H23 (xtreame18)
some body have any clue i'm lost on what to do
Old Mar 21, 2004 | 12:25 PM
LudeyKrus's Avatar
To set the cam timing, you just set the crank to TDC, and check the arrow marks on the cams; they should point straight at each other.
Old Mar 22, 2004 | 12:26 PM
Jagan'92's Avatar
How about setting the valves tighter than spec.?
https://honda-tech.com/zerothread?id=807535
Bender C/F
Mar 16, 2010 10:36 AM
mixmastermatt
May 16, 2007 09:09 PM
ml1
Mar 28, 2007 02:32 PM
Peters1983
Apr 24, 2003 05:55 PM
brawl
Dec 17, 2002 02:28 PM
