adjusting nut problem/question
Old Mar 22, 2004 | 06:37 AM
c1civic's Avatar
Default adjusting nut problem/question
we finally got the h22 in, but we loosed this bolt and now we need to tighten it up agani. is this gonigto thorugh off the balance of the belts under the timing cover or is this fine, please let me know asap
thanks
Old Mar 22, 2004 | 07:05 AM
Filthy Focker!'s Avatar
Default Re: adjusting nut problem/question (c1civic)
You need a spell checker. What bolt are you talking about???
fs
Old Mar 22, 2004 | 07:06 AM
AndyGCT's Avatar
Default Re: adjusting nut problem/question (filthy_shovel)
I think thats how they talk in ohio...
Old Mar 26, 2004 | 06:51 AM
c1civic's Avatar
holy **** , just looked back an i cannot type for ****. ok the adjsusting nut..which is on in the timing cover is loose. we tightened it down at one time, but we had to loosen it for some reason. Can we jsut go ahead and tighten it, or do we have to redo something under the timing cover
...sorry about the shity typing
Old Mar 26, 2004 | 07:50 AM
Jagan'92's Avatar
Default Re: (c1civic)
If you loosened it, you should have had a bolt in the adjusting lever lock.
Old Mar 26, 2004 | 11:19 AM
c1civic's Avatar
yes its the bolt is still in there but i was jsut making sure i an jsut tighten it back up with no probs
Old Mar 26, 2004 | 12:28 PM
LudeyKrus's Avatar
So it's the 14mm bolt for the tensioner?
If so, are you using the manual tensioner? I would turn the motor over by hand to make sure it has the correct tension on it before tightening it back up.
ehrkeith
11
Apr 28, 2012 05:13 PM
MC Slide Hammer
Mar 23, 2011 02:25 PM
dephtone
Dec 1, 2008 06:59 AM
Hoosier Daddy
Oct 11, 2003 02:04 AM
3rdGteg
Jan 28, 2002 02:54 PM
