code 23 knock sensor! code 7 TPS
Old Mar 23, 2004 | 09:31 PM
99spanishGT
Guest
Posts: n/a
Default code 23 knock sensor! code 7 TPS
how do i fix both?? i checked and KS is hooked up so is the unit fucked up? and how do i fix tps? also i had code 41 O2 and also elecric air control but they went away. dont know how? any help is appriciated!
Old Mar 24, 2004 | 05:24 AM
prelittlelude's Avatar
Default Re: code 23 knock sensor! code 7 TPS (spanishlude)
i think you want track down that TPS code first, when i started my f22b2 hybrid motor, i started it without the knock sensor pluged in and it didn't throw a code,
i think something else is fucked and its making your knock sensor read all kinds of crazy ****
Old Mar 24, 2004 | 12:49 PM
99spanishGT
Guest
Posts: n/a
bump!
Old Mar 24, 2004 | 02:06 PM
Cottonwoodz's Avatar
Default Re: code 23 knock sensor! code 7 TPS (prelittlelude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by prelittlelude &raquo;</TD></TR><TR><TD CLASS="quote">i think you want track down that TPS code first, when i started my f22b2 hybrid motor, i started it without the knock sensor pluged in and it didn't throw a code,
i think something else is fucked and its making your knock sensor read all kinds of crazy ****</TD></TR></TABLE>
F22b2 block, has a knock sensor???
Old Mar 24, 2004 | 06:47 PM
JR Integra's Avatar
Help this guy and help me i have the same problem with my 95 supercharged GSR TPS and knock sensor DAMN THEM.
Old Mar 24, 2004 | 07:38 PM
99spanishGT
Guest
Posts: n/a
Default Re: code 23 knock sensor! code 7 TPS (JR Integra)
a guy at my work said replace TPS first then see if its still retarded! should i or do knock first?
Old Mar 25, 2004 | 07:06 AM
99spanishGT
Guest
Posts: n/a
bump!!!!!!!!!!!!!!!!!!!!!!
Old Mar 25, 2004 | 09:53 AM
Default Re: code 23 knock sensor! code 7 TPS (Cottonwoodz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cottonwoodz &raquo;</TD></TR><TR><TD CLASS="quote">
F22b2 block, has a knock sensor???</TD></TR></TABLE>
nope , thats why i said , when i started my motor it wasn't pluged in, there was no point to let it just hang in mid air, and there is no place to screw it in, so i just didn't plug it in.
Old Mar 25, 2004 | 07:45 PM
99spanishGT
Guest
Posts: n/a
nope , thats why i said , when i started my motor it wasn't pluged in, there was no point to let it just hang in mid air, and there is no place to screw it in, so i just didn't plug it in.</TD></TR></TABLE> ahh i see stop getting OTQQ
Old Mar 26, 2004 | 06:49 AM
99spanishGT
Guest
Posts: n/a
bump
Old Mar 26, 2004 | 10:58 AM
seriously man jsut take it one at a time, start first by eliminating the 02 problem, then take care of the TPS, and see what happens from there, its got to be either bad wiring, bad sensor, or bad ecu.
Old Mar 26, 2004 | 12:40 PM
99spanishGT
Guest
Posts: n/a
there is no O2 ir electronic air just knock an tps
terplaygroun_dc2
Oct 23, 2008 09:38 AM
jdmland
Sep 4, 2008 11:17 AM
Grip
Jul 13, 2004 08:43 AM
roadawg
Feb 11, 2004 01:10 PM
