Remove ABS??
Old Mar 20, 2004 | 12:47 PM
killa_lude's Avatar
Default Remove ABS??
has anyone every tried to remove the abs in their 4th gen lude...wouldnt it be pretty straight forward?
Old Mar 20, 2004 | 01:03 PM
PriMaTe's Avatar
Default Re: Remove ABS?? (killa_lude)
the question is...why?
Old Mar 20, 2004 | 01:11 PM
killa_lude's Avatar
Default Re: Remove ABS?? (PriMaTe)
weight...make more room under the hood...
Old Mar 20, 2004 | 04:26 PM
killa_lude's Avatar
no one has ever removed their abs?
Old Mar 20, 2004 | 04:28 PM
Matgallis's Avatar
ins't it just a computer... that's not very much weight...
Old Mar 20, 2004 | 06:32 PM
killa_lude's Avatar
Default Re: Remove ABS?? (Matgallis)
no, theres a abs unit, on the passenger side...its heavy.
Old Mar 20, 2004 | 06:41 PM
99spanishGT
Guest
Posts: n/a
i remember some guys who rallyed there preludes made a switch to turn it on and off. i guess to lock up the wheels around a turn? but as far as weight i think its like 40 lbs total. some guys just weld the unit to the body insted of using the mount to save weight!
Old Mar 20, 2004 | 06:55 PM
junbb1's Avatar
Default Re: Remove ABS?? (spanishlude)
i am going to be doing it in a week or so. you will need to get all 6 brake lines from a prelude s model or have custom ones made. you will also need a prelude s proportioning valve. i already have the lines i just have to get the valve.
Old Mar 21, 2004 | 12:20 AM
killa_lude's Avatar
Default Re: Remove ABS?? (junbb1)
yeah i will just use the lines that i have now...they should work shouldnt they, i need that valve then too.
Old Mar 21, 2004 | 11:20 AM
junbb1's Avatar
if your car has abs you wont be able to use the lines you have due to the routing changes from abs to non abs.
Old Mar 21, 2004 | 02:21 PM
prelittlelude's Avatar
yeah i am going to be removing my abs as well, the abs using is HUGE, and now that i have better brakes i hate having abs always kicking in when the front start to lock alittle,
like junbb1 says you need all the stuff fromt he S and the only think i am not sure about is if the lines from the S are going to screw in to the brake master cylinder
Old Mar 22, 2004 | 08:27 AM
killa_lude's Avatar
Default Re: Remove ABS?? (prelittlelude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by prelittlelude &raquo;</TD></TR><TR><TD CLASS="quote">yeah i am going to be removing my abs as well, the abs using is HUGE, and now that i have better brakes i hate having abs always kicking in when the front start to lock alittle,
like junbb1 says you need all the stuff fromt he S and the only think i am not sure about is if the lines from the S are going to screw in to the brake master cylinder </TD></TR></TABLE>
yeah they sould screw in...but you know how you got the four lines going into the abs unit, well i was thinking just get 2 "Y splicers" and run the front brakes to the Y fitting then one line to the master cylinder and the other 2 lines the same way....
Old Mar 23, 2004 | 01:12 PM
killa_lude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by junbb1 &raquo;</TD></TR><TR><TD CLASS="quote">i am going to be doing it in a week or so. you will need to get all 6 brake lines from a prelude s model or have custom ones made. you will also need a prelude s proportioning valve. i already have the lines i just have to get the valve.</TD></TR></TABLE>
yeah i need a valve too....anyone have one?
f3rnlude
Oct 23, 2009 01:05 AM
IT'S ME DAVID
Sep 10, 2009 08:27 PM
richjr
Oct 6, 2008 04:21 PM
Vcastro
Oct 13, 2006 08:46 AM
JimmyAtlantis
Dec 8, 2005 10:38 AM
