intake ideas
Old Mar 22, 2004 | 12:07 PM
cbmprelude's Avatar
* B A N N E D *
Default intake ideas
A friend of mine is building me an intake for my 5th gen. I was wondering which is a better choice for airflow... to a) Build the pipe from the intake manifold, up to the stock air filter box and just put my cone filter there or to b) have the pipe bend down behind the front right turn signal (removing the resonator box of course) and also shaving the stock hair hole wider so my pipe can pass through it. Also would it be a good idea to take out the vent under the turn signal so air from the outside flows directly to my cone filter? Will I have water problems? Also what is the best way to cut the metal around the stock air hole for my piping and to keep it from rusting? And it's a K&N filter by the way.
Old Mar 22, 2004 | 12:17 PM
rubix777's Avatar
Default Re: intake ideas (cbmprelude)
look up cold air intake and short ram intake
Old Mar 22, 2004 | 03:31 PM
cbmprelude's Avatar
* B A N N E D *
Default Re: intake ideas (rubix777)
bump
Old Mar 23, 2004 | 08:22 AM
SuperSlow's Avatar
See if you can get tips from Satan. He is making one for 4gen out of CF.
Old Mar 23, 2004 | 11:34 AM
BluLude's Avatar
Default Re: intake ideas (SuperSlow)
have the pipe bend down to where the resonator is...cold air intake style
homesauce's Avatar
cut that hole with a dremel, i wouldnt cut the plastic shielding underneath, u may have water spray up in there, and yea i'd bring it down like u said to make a cold air.
joshuaaaronalpert
Sep 22, 2006 10:47 AM
Iomega01
Aug 9, 2005 12:51 PM
IrJhOn
Sep 9, 2004 06:27 AM
LFA Squad :: iTO
Dec 8, 2003 03:40 PM
MechEng
Mar 13, 2002 05:05 AM
