Camber Kit Question
Old Apr 29, 2005 | 09:35 AM
J-Ho's Avatar
Default Camber Kit Question
I have an 01 Lude, just wondering how low can you go before you need to get a camber kit?
Old Apr 29, 2005 | 09:52 AM
bad-monkey's Avatar
Default Re: Camber Kit Question (J-Ho)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by J-Ho &raquo;</TD></TR><TR><TD CLASS="quote">I have an 01 Lude, just wondering how low can you go before you need to get a camber kit? </TD></TR></TABLE>
you don't "need" a camber kit until you hit -3.5 degrees or so of camber. camber doesn't kill tires, toe does.
you might need a camber kit to even out camber from side to side, sometimes the differences b/w left and right can be pretty drastic.
camber kits exist for performance reasons, not tire economy.
Old Apr 29, 2005 | 10:29 AM
mgags7's Avatar
you can go MAD low y0!
like monkey boy said....you dont need them....
just get an alignment when you slam your ride and it will be ok....
Old Apr 29, 2005 | 11:13 AM
J-Ho's Avatar
Thanks guys
Old Apr 29, 2005 | 11:44 AM
RDN's Avatar
RDN
Default Re: (J-Ho)
Yes this is true, I have an '98 prelude base lowered on Neuspeed racing springs (2.5") and don't need a camber kit, my caber is dialed in at -1.7 degrees at all four corners yet my toe is 0. My tires wear evenly no problem. What I did was buy a 3 year alignment at Goodyear ($99) and go in every 4 months to make sure my toe is fine. Out of spec toe will cause your tire to where on the inner edges real bad though. Since the front camber kit is only an adapter (like the short shifter, wtf) you'll have serious clearance issues if ur sporting big rims and lowered (I run 18s) with a camberkit. Take it from me the lude can be dropped pretty low without serious camber issues (not like some civics I see that look like the DeLorean on Back to the Future 2) but remember toe is the key.
bmoua
Suspension & Brakes
Oct 19, 2007 04:00 AM
4drteg916
Suspension & Brakes
Feb 22, 2007 12:07 PM
pr0phet
Nov 22, 2005 03:59 PM
TegoDC5
15
Oct 20, 2004 10:01 AM
JunIntegra
Apr 4, 2004 09:09 AM
