Timing... HELP
Old May 3, 2005 | 02:32 PM
mdj_ge's Avatar
Default Timing... HELP
I reccently changed my fly wheel to ACT street lite and now my timing is only reading at 13 degree FULL ADVANCE... HELP....
Old May 3, 2005 | 09:20 PM
mdj_ge's Avatar
Default Re: Timing... HELP (yangja)
anyone had this before???
Old May 3, 2005 | 09:23 PM
SKDRCR's Avatar
Did you mess with the cams or the TB at all?
Are you sure you're reading the correct timing mark on the flywheel?
Old May 3, 2005 | 09:35 PM
mdj_ge's Avatar
Default Re: Timing... HELP (SKDRCR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SKDRCR &raquo;</TD></TR><TR><TD CLASS="quote">Did you mess with the cams or the TB at all?
Are you sure you're reading the correct timing mark on the flywheel?</TD></TR></TABLE>
nope... never messed with it.. and yeah i am reading the correct mark.
Old May 4, 2005 | 05:17 AM
Monkey Fing a Coconut's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yangja &raquo;</TD></TR><TR><TD CLASS="quote">I reccently changed my fly wheel to ACT street lite and now my timing is only reading at 13 degree FULL ADVANCE... HELP.... </TD></TR></TABLE>
so it is at 13 degrees BTC, or it is advanced 13 degrees beyond stock 15, so its at 28 degrees BTC???
Old May 4, 2005 | 05:38 AM
IHateJDM's Avatar
Default Re: Timing... HELP (twistedbydezign)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by twistedbydezign &raquo;</TD></TR><TR><TD CLASS="quote">
so it is at 13 degrees BTC, or it is advanced 13 degrees beyond stock 15, so its at 28 degrees BTC???</TD></TR></TABLE>
I don't even think it would run at 28 degrees BTC.
Old May 4, 2005 | 04:41 PM
mdj_ge's Avatar
the distrubutor is advanced, all the way to the fire wall, where it could not me advance any more... and when using a timing gun, it's reading 13 deg... would this be a cause of not installing the fly wheel in the right place???
Old May 4, 2005 | 05:01 PM
IHateJDM's Avatar
i don't see how you could install the flywheel wrong, unless you put it on backwards, and you would def know if you did. I bet your one tooth off on your cam gear. That happened to me once too. with the dizzy turned all the way to the firewall it ran best, and if you put it all the way towards the bumper, it would die. right in the middle I was slower than a 400 lb man on a moped. my exhaust cam was one tooth off and the intake cam was right. IMO, redo timing from scratch and see what happens.
k_lude
Jan 28, 2012 07:50 PM
BoostedH23a1
Oct 15, 2006 08:39 PM
dsmIA
Jul 12, 2005 08:11 PM
platinum00
Dec 17, 2004 08:53 AM
ch0o on this
Sep 18, 2004 10:05 AM
