how do i bleed my clutch system?
Re: (KB96VTEC)
nope. follow the hydrolic lines that run from the back of the tranny over the top of it to the front of the tranny. if u look you should be able to find it pretty easily.
front of the block/tranny, hydraulic lines running to the slave cyl, there should be a nipple where you open and bleed it.
basically bleed it like your brake system.
Re: (xthephilx)
It is an 8mm bleed screw that is located near the clutch fork, on the slave cylinder, towards the front of the engine, near the radiator/exhaust manifold.
To bleed it:
open screw, push clutch pedal, close screw, release clutch pedal and repeat. Keep the clutch fluid full the entire time.
To bleed it:
Re: how do i bleed my clutch system? (KB96VTEC)
im currently trying to do this, and my clutch goes straight to the floor. Even if you press the clutch just a little, it SLAPS to the floor..
what am i forgetting?
Re: how do i bleed my clutch system? (TylerC161)
close the bleeder screw when you are done..?
or your slave cylinder may have gone bad...i ve gone through about 4 of the cheap ones. look and see if its leaking.
u have to pump the fluid in the nipple with, like oilcan like this one http://www.wordpower.ws/phonics/oilcan-w225.gif, then the clutchpedal will go up l
Be sure the pump is really clean
TedR719
18
04-27-2004 07:29 PM
