Amp hookup?
Old Jan 30, 2006 | 06:25 PM
figsclay's Avatar
Default Amp hookup?
I'm in the process of hooking up my amp. I don't know where to run my power wire from the battery. I looked for anexisting hole from the engine bay but found nothing. Should i drill a hole or run it outside the car somehow? Help is appreciated.
Old Jan 30, 2006 | 06:36 PM
93h22a1vtec's Avatar
Default Re: Amp hookup? (figsclay)
drill... it will come in handy later... drill it big at least .5in
Old Jan 30, 2006 | 06:48 PM
arkosh.kovash's Avatar
* B A N N E D *
what generation? i have a 5th gen and ran mine through a factory hole at the firewall. if you remove the under the hood fuse box (directly behind the battery) there is a boot covering a set of wires running through the firewall. pull part of the boot back and you can squeeze a hefty gauge wire through this hole. it comes out on passenger side not too far up and can be easily run through the console or under the carpet, depending on amp location.
Old Jan 30, 2006 | 07:33 PM
uneek4dr's Avatar
in the 4th gen there is a hole that runs in the passanger side by the footwell area
KILLAB17VTEC
Audio / Security / Video
Jul 11, 2009 01:48 PM
philosofy1
Dec 18, 2007 02:12 PM
skingfreak
May 4, 2006 06:13 PM
Jxi8s2k
Oct 12, 2005 07:59 AM
Flamenco-T
Jul 18, 2001 09:59 PM
