D4 Light Blinking Help
Old Feb 1, 2006 | 11:37 AM
bobbysunshine's Avatar
Default D4 Light Blinking Help
Ok Just did a motor swap 92 prelude H23a to 93 H23a everything is fine runs perfect. But now the D4 light started blinking. I know this is a Transmission error but I dont have any expierience with Prelude Trans. I checked fluid its red and good It shifts fine maybe a little rough but no slipping. How do I check this? Any help welcome. TIA
1992 Prelude H23a SI Automatic Transmission
Old Feb 1, 2006 | 12:54 PM
K-Spec's Avatar
Default Re: D4 Light Blinking Help (bobbysunshine)
did you check all the sensor plugs and make sure they're all connected tightly. and are you throwing any CEL?
Old Feb 1, 2006 | 04:33 PM
Default Re: D4 Light Blinking Help (khalal538)
checked all the sensors they are fine. Pulled bat cable off reset computer cleared for a minute took for a test drive seems to start when i hit OD D4 starts blinking. CEL is not on Ill do a check anyway see if it throws me a code. Do 92 preludes have a TCM?
Old Feb 1, 2006 | 07:11 PM
Does anyone know how to check D4 TCM codes on a Prelude? My CEL isnt on No codes there. I googled everywhere and only foud Accord TCM info. All help Appreciated!
Trans Problems Suck!!!
Old Feb 2, 2006 | 03:54 AM
syntax.'s Avatar
you have to check the helms. there is a way to decode the d4 light just like you would the cel, but im not exactly sure.
popitmon
Apr 5, 2014 01:33 PM
clamas13
Oct 12, 2007 07:54 AM
H22A1TLUDE
Dec 14, 2004 04:56 PM
1fastvw
Jul 26, 2004 11:57 AM
Clydsdal
Sep 21, 2003 08:15 AM
