removing front engine mount
Old May 23, 2006 | 03:45 PM
hamadiscool's Avatar
Default removing front engine mount
My front engine mount was broken and i just got a replacement. How in the world are you suppose to reach the 3 nuts that hold the mount to the front part of the car??!?!? I can barely touch those nuts with my finger let alone use a wrench etc to unscrew it. Help please!!!
Old May 23, 2006 | 04:22 PM
chitownrida's Avatar
i used a super long extension to get at it
prolly like foot long extension
Old May 23, 2006 | 08:03 PM
mkazm83's Avatar
Default Re: (chitownrida)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chitownrida &raquo;</TD></TR><TR><TD CLASS="quote">i used a super long extension to get at it
prolly like foot long extension</TD></TR></TABLE>
I also used a wobble extention in conjunction with the regular extention.
Old May 23, 2006 | 08:06 PM
darkspector's Avatar
LoL wobble extension
Old May 23, 2006 | 08:26 PM
DTPrelude's Avatar
drop the subframe
Old May 23, 2006 | 08:29 PM
Default Re: (DTPrelude)
I got the bracket out but i am having a lot of problem with the mount. There is no space at all and using the extension is starting to wear the nuts and is letting me apply the force in the wrong direction. Any help? Does autozone have any "free tools" that could help? Thanks
Old May 23, 2006 | 09:11 PM
Hawkze_2.3's Avatar
Default Re: (hamadiscool)
Take the rad fans out and if you can, take the radiator out.
Old May 23, 2006 | 09:21 PM
Default Re: (Hawkze_2.3)
I took out the battery, the radiator fan, two radiator hoses, header heatshield, and some sort of bracket for holding a radiator hose. Need help!!
Old May 23, 2006 | 09:40 PM
Hawkze_2.3's Avatar
Well, if you took out the rad hoses. then it'll be easy to take out the radiator Then you should be able to get a long breaker bar through the front bumper....unless you have AC and PS crap there.
Old May 24, 2006 | 11:58 AM
YEAH! i got it out finally....i broke my wrench doing it too . Now that i have everything back together with the new mount. I drove around and when my car is at a stop, there are alot of vibrations...what did i do wrong? Did i not tighten the nuts hard enough?Thanks for all the help guys
Old May 24, 2006 | 01:02 PM
connvict's Avatar
this thread annoy's me..........
go back and re-check your work......
Old May 24, 2006 | 01:05 PM
Default Re: (connvict)
then stop reading it,i did check my work but i am not sure if a new solid mount is suppose to do that or not. If it is not suppose to do that then i would take it to a mechanic or something but if it is suppose to do that then i can have a piece of mind.
Old May 24, 2006 | 01:08 PM
twistedbydezign's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hamadiscool &raquo;</TD></TR><TR><TD CLASS="quote">YEAH! i got it out finally....i broke my wrench doing it too . Now that i have everything back together with the new mount. I drove around and when my car is at a stop, there are alot of vibrations...what did i do wrong? Did i not tighten the nuts hard enough?Thanks for all the help guys</TD></TR></TABLE>
a new mount will be stiffer than an old worn out mount, so some more vibration than before is normal, but if it seems excessive then something could be loose
Nicram
Oct 27, 2005 12:08 PM
CIVIX
Mar 18, 2002 06:03 AM
Ri5e
Dec 31, 2001 09:41 AM
balistic CRX
Dec 27, 2001 04:37 AM
Batoutahell
Sep 1, 2001 04:02 PM
