TBS sensor
Old May 26, 2006 | 12:13 AM
CRX 2.0V-T's Avatar
Default TBS sensor
hey guys, can you prelude guys tell me if the TBS sensor of Prelude is same as civic? cuz mine is broke and im doing H22 swap. Oh yeah H22A4 (97 the engine) and the TBS sensor from 95 civic
Old May 26, 2006 | 05:33 AM
Ross 2.0's Avatar
In a Junkyard near you.
do you mean the Throttle Position sensor?
Old May 26, 2006 | 05:36 AM
(null).exe's Avatar
From: Forced to leave Austin, TX for, Oklahoma, USA
Default Re: (MooGoCow3)
his is special, it's a Throttle Bosition Sensor, it's better than a normal sensor.
Old May 26, 2006 | 07:39 AM
Hawkze_2.3's Avatar
Default Re: TBS sensor (Lak of Speed)
All Honda TPS's should be the same other than some point up and some point down. As far as I know......
Old May 26, 2006 | 08:53 AM
CRX 2.0V-T's Avatar
Default Re: TBS sensor (Hawkze_2.3)
thanks alot, oh yeah, about the ecu and fuel injector. I want to use P28 ecu, is that mean i have to use resistor box to go with the stock prelude injectors? and what happen if i dont have resistor box?
Old May 26, 2006 | 09:04 AM
Eddiebx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hawkze_2.3 &raquo;</TD></TR><TR><TD CLASS="quote">All Honda TPS's should be the same other than some point up and some point down. As far as I know......</TD></TR></TABLE>
yes for the most part they are all that same style that are on like all the cars from 90-02 honda motors. but i thikn some of the older hondas have slighty differnnt ones, and the newer k-series has a differnt one too i think.
but as long as they look the same, then it will work,
Old May 26, 2006 | 09:09 AM
Hawkze_2.3's Avatar
Default Re: TBS sensor (Eddiebx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eddiebx &raquo;</TD></TR><TR><TD CLASS="quote">
Yeah, back when they used DPFI (direct port fuel injection, I think it was called) where it was like half carb-half injection and they had a different type of throttle body.
2009HondaAccord
Feb 18, 2018 06:41 PM
gizmo923
Sep 12, 2017 08:59 AM
bubbaracer
Oct 17, 2013 09:01 AM
bluelude2.3
May 20, 2007 12:29 PM
samvtecaccordsport
Apr 27, 2004 04:48 AM
