preoblem with e-brake, help needed
Old May 30, 2006 | 06:58 PM
msinsky14's Avatar
Default preoblem with e-brake, help needed
my e-brake isnt working correctly.........when I first noticed it couldnt keep me parked on a hill, I took the armrest out and tightened it up..........now it stays on a hill but when I pull it on a street the back wheels roll almost like normal........if anyone could inform me anout a thread on tightening the brake that would be great in case I did it wrong.........thanks in advance
Old May 31, 2006 | 08:35 AM
K-Spec's Avatar
Default Re: preoblem with e-brake, help needed (msinsky14)
the bolt that needs to be tightened is the one (12mm like apeng said) with the spring on the other end. if that doesn't work, you may need a new cable line.
Old May 31, 2006 | 10:11 AM
limpmode's Avatar
Default Re: preoblem with e-brake, help needed (khalal538)
what do you mean when you pull it on the street the back wheels roll like normal. if it holds you on a hill, it should be fine. unless you're doing e-brake turns everywhere...
basically an ebrake is not meant to stop you on a dime (or really at all) while moving.
Old May 31, 2006 | 02:10 PM
msinsky14's Avatar
Default Re: preoblem with e-brake, help needed (limpmode)
yeah i tightened it and it holds me on a hill finally, it didnt used to, and now I just want to be able to screw around and pull it around turns if theres anyway to fix it?
Old Jun 3, 2006 | 03:39 PM
limpmode's Avatar
ah i see. what type of 4th gen, if i'm not mistaken different models have different brakes right? I can lock up the rears ont my 5th at speed too, found out when drunk friend thought it would be funny.
anyway i think the 4th's with the H22 had bigger brakes all around, maybe yours are smaller and that's why.
so why do you need your ebrake at 40 mph? sounds like an accident waiting to happen.
Old Jun 3, 2006 | 04:27 PM
msinsky14's Avatar
not at 40, but I like to screw arounfd during the winter, thats prolly why Ihave rust in my engine bay .......anyways, I just feel like everything needs to be working correctly........please give some help, all is appreciated
Old Jun 5, 2006 | 06:57 AM
limpmode's Avatar
what i'm saying is it's working fine. it's only meant to hold you in place really, not stop. it's an E-mergency brake, so if your brakes go out you can use it to slow yourself down, but snow and rain are bad times to use it.
Old Jun 5, 2006 | 07:22 AM
Hawkze_2.3's Avatar
Just tighten the bolt under the console until you get it where you want. If you're wearing out your rear pads by 'drifting' everywhere, you'll need to tighten it more often...
Old Jun 5, 2006 | 04:44 PM
msinsky14's Avatar
Default Re: preoblem with e-brake, help needed (Hawkze_2.3)
I actually looked at my rear brakes and I need new pads and rotors, so thats probably why
Old Jun 5, 2006 | 06:32 PM
limpmode's Avatar
this whole thing was over brake pads?
Old Jun 6, 2006 | 05:02 PM
msinsky14's Avatar
Default Re: preoblem with e-brake, help needed (apeng09)
haha, yeah, maybe I should put my front wheel drive car in Tokyo Drift and see who wins.........BOOOOYAAA, I'll beat any drift car in my prelude, yeah right!
Say Anything
Aug 22, 2011 09:23 PM
Mike D
Nov 14, 2005 06:37 AM
Tomatohatch
Oct 7, 2004 09:42 PM
importimage
Jun 6, 2004 03:35 AM
feelthebreak
Oct 14, 2002 08:50 AM
