2001 engine swap
Old May 31, 2006 | 08:22 AM
The7169's Avatar
Default 2001 engine swap
I need some help. I've put a 2001(wrecked with airbags deployed) h22a4 engine(w/wiring harness, computer, SRS unit, etc...) in a completely stripped 98 prelude. The engine was running perfect when I swapped everything, now it just spins over. I've narrowed it down to the injectors not firing. You can sparyed gas in the trottle body and it will run. Can anyone help me?
Old Jun 1, 2006 | 05:37 AM
The7169's Avatar
Default Re: 2001 engine swap (The7169)
I see a few people have looked at this but nobody has any ideas?
Old Jun 1, 2006 | 02:29 PM
darkspector's Avatar
are they wired correctly, fuel pump working properly, check your whole fuel system
Old Jun 2, 2006 | 06:14 AM
prelude1897's Avatar
I've heard that some of the sensor from 97-98 don't match up with the 99-01 motors. I could be wrong, but double check all your connectors. I'm in the process of doing a motor swap to my Prelude as well, and that's what I was told before I bought the motor
Old Jun 2, 2006 | 10:54 AM
The7169's Avatar
Default Re: 2001 engine swap (prelude1897)
There is one connector that is different(wires are color coded the same), we changed that. The EVAP system totally changed and we changed out the fuel tank evap tank, etc... Every thing has fell into place perfect (but it don't start). I don't know if there is a reset on the ECU. Thank you. Any help would be greatly apperciated.
mechanix619
Mar 30, 2010 05:53 PM
xxstuntin4life
Nov 2, 2009 02:11 PM
KyoCivic98
Jul 29, 2009 01:31 AM
meagainsttheworld
Sep 16, 2006 10:02 PM
