H22A with a problem...need help
Old May 24, 2006 | 04:05 PM
streetlegalh22's Avatar
Default H22A with a problem...need help
I have an H22A that sounded like i broke the timing belt the other day. was driving, downshifted, went from 4K to 5K rpm when i heard a snap. engine immediately went dead, coasted to a stop. the sound it makes when i turn the key is the same as if the timing belt is broken and all i'm doing is spinning the crankshaft, but the belt is still tight. any ideas what it could be?
Old May 24, 2006 | 05:42 PM
lostkoz's Avatar
Default Re: H22A with a problem...need help (streetlegalh22)
you missing any teeth on yur belt
Old May 24, 2006 | 05:51 PM
BB6racer's Avatar
well the motor isn't starting, so either way you'rer gonna have to pop the hood and see whats up and fix it. inspct everything and let us know what happened.
Old May 24, 2006 | 08:24 PM
as far as i can tell, there's no teeth missing on the belt. i've pulled the valve cover and the upper timing belt cover. when i tried to turn the cam to cycle through the belt, it wouldn't move at all. the side of the belt on the back side of the block was tighter than the front, but not by too much. the belt actually looks clean and new, as far as i could tell the block has under 30K miles on it anyway. it's clean under the valve cover. nothing's wrong except the starter will spin without cranking the block. could i have broken a crank shaft or something? the ping or snap i heard right before the car shut off was almost exactly the same as hitting the rev limiter, but it popped at 4.8-5.1K instead of 8K. enough info for anyone to work with? i don't really want to strip the whole block down if i don't have to.
Old May 24, 2006 | 08:29 PM
mgags7's Avatar
so the starter turns the flywheel and the crank pulley doesnt spin??
then yes you broke the crank.....
be more descriptive with your thread titles from now on
Old May 24, 2006 | 08:38 PM
shutta's Avatar
I odn't know man, pull you starter and see what's up with that.. if the starter goes, but doesn't crank the engine, that's where i'd look
Old May 25, 2006 | 04:58 AM
bluedlude's Avatar
Default Re: (shutta)
if it was a starter you wouldnt have just died...
your crank would still be able to turn...
you wouldnt have heard anything bust...
sounds like a broken crank or rods.
withoutlimitslude
Jul 19, 2010 02:58 PM
orangeaccord
Jul 11, 2009 03:05 PM
DarkBB4
Feb 13, 2006 06:40 PM
GraphiteAccord
Apr 24, 2002 09:26 PM
