valve guides?
Old May 27, 2006 | 04:53 PM
BDRphaSe2's Avatar
Default valve guides?
how do you remove em? is there a special tool? or is it just better to take it to a machine shop
Old May 27, 2006 | 05:27 PM
akstunt600's Avatar
Default Re: valve guides? (BDRphaSe2)
u have to heat up the head, but just take it to a machine shop. if ur replacing them b/c a bent valve the seats r going to be marred anyway so u need to have the seats cut to fit the new valves or else ur just not goin to get a proper seal. i would reccomend replacing the valve seals too while ur head is off
Old May 27, 2006 | 05:32 PM
BDRphaSe2's Avatar
im rebuilding the motor, and the guides and seals were leaking, i wanted to have em pulled, then have the head hottanked, then replace the guides/seals
Old May 27, 2006 | 06:13 PM
akstunt600's Avatar
Default Re: (BDRphaSe2)
heat up the head with some map gass and rip em out then, becarefull when replacing them its a delicate process they must be flush when re-installed u may also have to reheat the head to get them in too.
no special tool needed however there is one just use pliers
dominate9
Apr 14, 2020 02:10 PM
80 dolla crx hf
Sep 8, 2014 01:28 PM
solid gsr
Aug 26, 2006 07:12 PM
95lstegman
Feb 9, 2005 08:04 AM
biggie2005
Feb 26, 2004 06:23 PM
