Do I need a camber kit?
Old May 26, 2006 | 04:56 AM
2000blacklude's Avatar
Default Do I need a camber kit?
I am planing on dropping my 5th gen lude about an 1.5". Do I need a camper kit or will just a good alinment be ok?
Old May 26, 2006 | 05:26 AM
(null).exe's Avatar
From: Forced to leave Austin, TX for, Oklahoma, USA
Your question has probably been answered already, check the search function. It's the big red link in the top right corner.
Old May 26, 2006 | 05:56 AM
ludespeed501's Avatar
My car is dropped 1.3" and I have zero camber. I think you will be fine with a 1.5" drop.
soundbomber's Avatar
Default Re: Do I need a camber kit? (2000blacklude)
you'll be fine with an alignment, be sure to specify that you'd like the toe to be zero'd out. that's the number one cause of premature tire wear
Old May 26, 2006 | 07:03 AM
The_Sober's Avatar
Default Re: Do I need a camber kit? (soundbomber)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by soundbomber &raquo;</TD></TR><TR><TD CLASS="quote">you'll be fine with an alignment, be sure to specify that you'd like the toe to be zero'd out. that's the number one cause of premature tire wear</TD></TR></TABLE>
X2
Old May 26, 2006 | 03:02 PM
paysos's Avatar
Default Re: Do I need a camber kit? (The_Sober)
i had a camber problem also, i just put in the tein s.tech springs which is about i 1.25 drop i believe, so basically u say all i have to do is align everything to zero???
Old May 26, 2006 | 03:31 PM
paysos's Avatar
Default Re: Do I need a camber kit? (apeng09)
so what should it be aligned to??
Old May 26, 2006 | 03:39 PM
98vtec's Avatar
moderator emeritus
Default Re: Do I need a camber kit? (paysos)
you want to align the toe to 0. toe adjusts the tires this way:
top view
the camber isnt the main issue when it comes to wearing out the tires. If you are running around pigeon toed, your gonna wear them out in no time.
Old May 26, 2006 | 03:47 PM
paysos's Avatar
Default Re: Do I need a camber kit? (98vtec)
even if the car is dropped?? im getting premature wear on the inside of the tire. is camber even adjustable on the lude??
Old May 26, 2006 | 03:48 PM
98vtec's Avatar
moderator emeritus
slightly through an alignment. But you cant do much changes with the camber. You can however correct your toe 100%
you would need a camber kit to make large adjustments.
Old May 26, 2006 | 04:43 PM
BB6racer's Avatar
take your car to an alignment shop after you lower the car and see what they say. some race/performance shops can do alignments without camber kits. the race shop i take my car to actually prefers not to work with camber kits and will charge you an extra $50 if you have one ("its just one more extra suspension part that has to be adjusted" they told me. i gladly took my car home, removed the camber kit and brought it back to them the next day).
Old May 26, 2006 | 06:00 PM
Brown-tec's Avatar
Default Re: (BB6racer)
i dropped my 5th gen lude on neuspeed sport and i got an alignment, my front camber was -1.5 left, -2.0 right, my bak were ok not that big. im thinkin of getting balljoint camber kit for teh front not sure yet.
Old May 26, 2006 | 07:10 PM
yOnKiNaToR's Avatar
Default Re: (Brown-tec)
some alignment guys like to set some toe in in the rear because the rear tends to toe out at speed. a certain amount of toe in is in spec for rear anyway.
in my personal experience, you don't really need a camber kit unless your camber is either:
uneven between sides (possible causing a pull)
above 2 degrees (gives minimal camber wear above that)
Old May 26, 2006 | 08:38 PM
prelude1897's Avatar
you'll be fine...No need for a camber kit
ahron
10
Jan 25, 2008 06:54 PM
Flava
Suspension & Brakes
26
Jun 9, 2006 08:56 AM
BLUE EH3
Suspension & Brakes
Jul 10, 2005 09:00 PM
kcjohnnyboy
Acura TL, RL & ZDX
Jun 19, 2005 07:57 AM
digitalh3lix
Apr 4, 2005 04:30 PM
