is it possible to...
i just bought a relay from autozone and got power straight from the battery. use the corner lights power wire(make sure you use corner light ,not the turn signal cause it will blink you fogs on and off if you use turn singal) for a switching source. then just run two power wires from the relay to the fogs and ground it trough the factory harnesses.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MadCityLude »</TD></TR><TR><TD CLASS="quote">instead of wiring a switch and all that, just run each sides 2 wires directly into the wires for your headlights. left into left headlight wires right into right headlight wires</TD></TR></TABLE>
what kind of half assed way of doing things is that. you would increse the draw through that circuit and blow fuses left and right. like i said already go to auto zone and get a relay. it will tell you how to wire it on the box its not that hard if you can use some zip ties and crimps....
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by my9thtry »</TD></TR><TR><TD CLASS="quote">
what kind of half assed way of doing things is that. you would increse the draw through that circuit and blow fuses left and right. like i said already go to auto zone and get a relay. it will tell you how to wire it on the box its not that hard if you can use some zip ties and crimps....</TD></TR></TABLE>
Really? I have had mine this way for 3 yrs on my lude and I have never blown a fuse! I also did this on a 92 camaro and never had a problem with it either!
damn i have the USDM fogs, and im tryna do the opposite...wire them to be on by themselves with the parking light, and then on with the headlights. anyone know how to on a 5th gen?
get a standard 4 or 5 pin relay with pins 85,86,87,87a(optional), and 30
Someone, correct me if I'm wrong but I believe the lights are positive switch,
so connect pin 87 to a power source(don't forget to put a fuse on that wire) connect pin 86 to ground, and connect pin 85 to one of the positive head light wires, and then connect pin 30 to the positive side of your foglights, and then connect the other ground side of your foglights to ground.....
Title your thread so people know what it is?
And also so people can search for it so the repost ****'s don't come out from their concentration camp and start bitching and moaning.
evolvedAP1
Jul 12, 2006 11:18 AM
