brake pad problem
Old Jul 1, 2006 | 06:50 PM
lude1888's Avatar
Default brake pad problem
Alright the metal backing on the back of one of the brake pads is slipping around. Because of that my brakes make a loud squeling sound. I tried to fix it by re-clamping it back on, and it worked for a little bit. My question is does anyone know what those metal slips on the back of the pads do? Is it o.k. to take it off?
Old Jul 2, 2006 | 12:06 AM
lude1888's Avatar
Default Re: brake pad problem (lude1888)
Also on another note I bled my brakes some and it came out nearly black, could this be the reason for the brake squeaking?
Old Jul 2, 2006 | 12:54 AM
Maharajamd's Avatar
I just got done putting on new rotors/pads & painting my calipers & painting my rims. Took a LOOONG time, but I just read some writeups so... The slips between your calipers are important, at least all the brake writeups I found said to put them back on. It also had me put a layer of "Stop Noise"...or whatever. Mine was a gel in a little pouch, the writeup showed him spraying it out of a can. Anyways the point is you put it between the calipers | slips | pads to stop the squealing...
Old Jul 2, 2006 | 03:51 AM
bluedlude's Avatar
those are the shims. the brake pads themselves are pretty fragile so the piston pushes against the shim and distributes the load a little more evenly and lets the pad vibrate a little without messing it up.
Old Jul 3, 2006 | 08:59 AM
lude1888's Avatar
Default Re: brake pad problem (bluedlude)
alright thanks
user 93082343
14
Mar 23, 2009 02:49 PM
InTeGrA_bLazEd
Oct 14, 2003 12:47 AM
yaya
May 19, 2003 08:18 PM
LshatchTurbo
Feb 19, 2002 08:53 PM
integra0260
Oct 21, 2001 08:09 AM
