Main Relay Compatability
Old Jul 7, 2006 | 07:57 AM
d3vilishSi's Avatar
Default Main Relay Compatability
I'm almost positive the main relay is going bad in my 92 Si b/c the car will ocassionally turn over but not start, however if I smack the dash (under the steering column) it fires right up. I know that the solder points can crack over time so I am going to try to re-solder them. I have an H23 but I was wondering if a B-series relay would work, just in case my relay is beyond repair? I have searched the forum for an answer but can't find anything.
Old Jul 7, 2006 | 08:42 AM
GlenWatkins's Avatar
Default Re: Main Relay Compatability (d3vilishSi)
If you really want to fix the main fuel relay, you need to UN-SOLDER the board and remove it. Then snap off the plastic covers, now you can get to the actual relay points. They are pretty small but if you have a set of those little files, you can clean them up. Then re-solder the board.
Unless there are shorts in the relay windings, you will have a "like new" relay.
People who have had success in simply re-soldering the board probably would have had the same success by simply un-plugging and re-plugging the connector. The idea that the factory solder joints have gone "cold" doesn't make much sense.
In other words...it's more likely that a CONNECTOR connection went bad than a solder joint.
Old Jul 7, 2006 | 12:44 PM
IceySC's Avatar
Default Re: Main Relay Compatability (GlenWatkins)
i think there the same anyone have any more info?
Old Jul 7, 2006 | 10:42 PM
Siegfried's Avatar
Is it possible to use Mitsuba RZ-0159 instead of 0139 ?
I also have a main relay problem, tried to resolder mine, thought it was OK as I didn' t have starting issue anymore but lately my car just shut off suddently in the middle of the road last week.
It didn' t happened again since I swap the main relay with the one from my second lude.
greyEG
Jun 28, 2013 01:59 PM
boost99
May 9, 2011 12:45 PM
90civicturboed
Jul 29, 2005 08:47 PM
C8V6C
Jan 20, 2005 09:46 PM
