rattle
Old Jul 7, 2006 | 04:29 PM
dohcvtecpower's Avatar
Default rattle
ok when i am driving my car and i get around 3rpm you can hear a slight rattle but if i accerlate or de. it you cant hear it any more..... i think its my exhaust rattling against something or my heat sheild??....who do ya'll think. o ya its a 01 lude
Old Jul 7, 2006 | 05:08 PM
Dameltajo's Avatar
Default Re: rattle (dohcvtecpower)
i got the same noise around 3K...i think its a leak from the headers but am not sure......
Old Jul 7, 2006 | 05:12 PM
98vtec's Avatar
moderator emeritus
Default Re: rattle (Dameltajo)
do you have an aftermarket header?
Old Jul 7, 2006 | 05:17 PM
LudeBehavi0r's Avatar
Could be you need a valve adjustment. How many miles on your car?
I get a little chatter between 700-760 rpm and anything lower/higher than that nothin.
Old Jul 7, 2006 | 10:22 PM
Dameltajo's Avatar
Default Re: rattle (98vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98vtec &raquo;</TD></TR><TR><TD CLASS="quote">do you have an aftermarket header?</TD></TR></TABLE>
Yes, am gonna get it check out soon....
i just got my valves adjusted about 7 months ago.......
Old Jul 8, 2006 | 12:08 AM
yes i have a aftermarket header
Old Jul 8, 2006 | 05:50 AM
98vtec's Avatar
moderator emeritus
look under the car and look at the bracket the goes to the back of the block holding the header.
Old Jul 8, 2006 | 10:56 AM
97BB6Type-SH's Avatar
im fully stock and have the same rattle...and its the catalytic rattling.
Old Jul 8, 2006 | 12:05 PM
asdfsad's Avatar
Default Re: rattle (97BB6Type-SH)
https://honda-tech.com/zerothread?id=1682447 fairly new thread same problem there. I also am stock 1999 base lude and I also have the same sound. Maybe it is just the heatsheild. Or Maybe as the link suggests, it could mean something is loose.
Old Jul 8, 2006 | 01:39 PM
Default Re: rattle (asdfsad)
i believe is something with the cat too...... o well just means i need to order a catco hi-flow cat soon
Old Jul 8, 2006 | 01:41 PM
98vtec's Avatar
moderator emeritus
why not find out what the problem is.....?
have you looked under there yet?
ur not going to be able to dianose the problem by twiddling your thumbs and waiting for someone 5000 miles away from you to guess what the problem is
Old Jul 9, 2006 | 10:21 AM
i got under there already and all the bolts were tight and nothing seemed wrong .....i mean seriously it sounds like something is rattling aroun in my cat....i had my friend give it a little gas and you can hear it slightly up til 3g then you can hear it then after its gets pass 3gs you cant hear it anymore.
tasco
Dec 16, 2007 12:47 PM
coolgsrguy
Mar 26, 2006 12:17 AM
es_squared
Sep 3, 2004 09:47 AM
builtprelude
Jun 10, 2004 10:28 AM
1slow_si
Apr 24, 2004 05:58 PM
