Brake bleeding order
Old Jul 6, 2006 | 05:16 PM
kb7709's Avatar
Default Brake bleeding order
Can't find anything on search. Can someone tell me the bleeding order for brakes on a 92 Prelude? I'm installing a new caliper on Saturday and want to flush the whole system while I'm into it. Anything special I should know about flushing them? Standard procedure good?
Old Jul 6, 2006 | 05:19 PM
shutta's Avatar
passenger rear, driver rear, passenger front, driver front.
in any car it's always best to start with the caliper that is furthest away from the master cylinder
Old Jul 6, 2006 | 07:35 PM
petern101's Avatar
Default Re: (shutta)
for a 4th gen
i'm looking at the helms right now
its Pass. Rear, Driver front, Driver rear, Pass. front
so shutta i think you should change your order
Old Jul 6, 2006 | 11:46 PM
TruNinja619's Avatar
Default Re: (petern101)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by petern101 &raquo;</TD></TR><TR><TD CLASS="quote">for a 4th gen
so shutta i think you should change your order</TD></TR></TABLE>
you can do that way...
or the way "shutta" posted... either will suffice...
Old Jul 7, 2006 | 09:58 AM
Eddiebx's Avatar
i think the honda specified order is pass rear, drivers front, drivers rear, pass front.
this is because you want to start with the line furtherest away from the master cylinder, and since the way honda brake lines are distributed, you have to cross bleed because, the drivers front and the pass rear are on one line, and what not.
how much this affects you in the long run, i am not sure,
shesinmyroom
Mar 16, 2012 06:58 AM
alex_s817
Jul 3, 2006 08:51 AM
JdmLub
Apr 25, 2006 06:01 PM
SlowSOHC-T
18
Apr 8, 2006 10:02 AM
sleepyhamsterlx
Mar 9, 2003 06:07 PM
