Electical ISSUES! help!
Old Jul 10, 2006 | 09:50 AM
DarkBB4's Avatar
Default Electical ISSUES! help!
Solid CEL: Tried swapping ECU's and fuses are fine.. what could be the problem?
there is the 2 ecu fuses in the cabin... is that it?
HELP! i must haev shorted soething when i ran gauges/apexi RSM.... but how could i locate it!
Modified by DarkBB4 at 1:59 PM 7/10/2006
Old Jul 10, 2006 | 10:06 AM
soundbomber's Avatar
Default Re: Electical ISSUES! help! (DarkBB4)
sounds like you have a short? did you solder everything?
Old Jul 10, 2006 | 12:59 PM
DarkBB4's Avatar
Default Re: Electical ISSUES! help! (soundbomber)
HELP!
Old Jul 10, 2006 | 01:04 PM
DarkBB4's Avatar
now ive been thinking..and before i posted ( i changed the original)
i had a short somewhere leading to smoking.. of a ground wire for the apexi rsm..... the wier melted all the way near the ecu, but the black/yellow wire on the ecu looked fine.. I just rewired it, but maybe something is damaged?.. thats why i used another ecu and the same problem occured...
My question is.. instead of using hte factory harness... can i run the ECU grounds.. directly to a ground on the chassis?
Old Jul 10, 2006 | 07:20 PM
DarkBB4's Avatar
help
Old Jul 10, 2006 | 08:44 PM
BB6racer's Avatar
you should be able to run the ground directly to the chassis, the harness is just for organization and cleanliness.
have you opening up the ECU? its not gonna mess anything up just by taking it apart and looking inside. there are only a few screws keeping it together. just look for anything that looks burnt or damaged inside.
also, does the motor even turn on or run?
Old Jul 11, 2006 | 09:21 AM
DarkBB4's Avatar
Default Re: (BB6racer)
ok tried to run a direct ground.. didn't work
NOW I have a question
WHAT (list) causes the cel to be solid:
Broken ECU (NOT IT, ive tried 2 working ones)
Improper Grounds?
Blown ECU/ACC fuse
What else?!
Old Jul 11, 2006 | 12:03 PM
DarkBB4's Avatar
Default Re: (DarkBB4)
i forgot...
i heard a buzzing sound on the drivers side... after i powered up the gauges... ( ithink its the main relay !!!)
88_hatch_ls
Apr 8, 2014 02:55 AM
hawj_boi_1
May 30, 2006 05:54 PM
punx04
Jan 2, 2006 01:05 AM
1320DRAGWORKX
Jul 28, 2004 08:20 PM
mockujin
Nov 17, 2002 06:06 AM
