help with high beam
Old Oct 23, 2006 | 08:00 PM
aoshiblade's Avatar
Default help with high beam
for some reason my high beam wont turn off. i check the fuse,blubs, and headlights. is there something else i forgot to check? So i just unplug it for now. any help would be appreciated.
Old Oct 23, 2006 | 08:03 PM
WhiteBB2's Avatar
Default Re: help with high beam (aoshiblade)
haha, im assuming you tried to use the headlight switch on the console...LoL.
Old Oct 23, 2006 | 08:51 PM
datac99's Avatar
Floating ground on the high beams?
Long story short I temporarly hardwired in a set of H4 bulbs in my JDM houseings... So I had both the low beams working right. I went back the other day to start wireing up the highs, figured I could just hook up the one positive wire for the high beams onto the high beam terminal of the H4 bulb and leave the ground floating. Low and behold I get high beams all the time. Going to go back and sort it out next weekend... But I'm guessing your problem is similar... Look for a loose wire on your high beams.
Old Oct 23, 2006 | 10:44 PM
aoshiblade's Avatar
Default Re: help with high beam (datac99)
i open the headlights and check if any wires was loose but that wasnt the problem.
James_Starks
21
Oct 16, 2022 12:23 PM
spikekautz
Honda Civic (2001 - 2005)
Jan 14, 2015 09:28 PM
EK VTi
Acura TL, RL & ZDX
Mar 6, 2006 08:22 AM
redEH2
Feb 2, 2004 01:34 PM
hondeducation
Jan 25, 2004 09:42 PM
