HID Problem
Old Oct 19, 2006 | 07:26 PM
drj73099's Avatar
Default HID Problem
I tried to install a simple pnp HID kit into my car and as far as the directions go and everything is connected correctly, they do not work and I have no idea on where to start on finding the issue. I have a 95 lude and i am using the stock harness and plugged it in both ways in the harness and these bulbs just don't come on. I had this issue before and sent it back and they said it works just fine but sent me a new pair anyway and I still have the same issue with them so I don't know what to do. Please help
Old Oct 19, 2006 | 09:05 PM
Prelude_2_NV's Avatar
Default Re: HID Problem (drj73099)
What kind of kit is it and it should be helpful if you posted pics of how you wired it in.
Old Oct 19, 2006 | 11:00 PM
darkspector2.0's Avatar
try hooking the ballast straight up to the battery, that will tell you if it works or not. and I would recommend running a relay harnes not of your stock harness. That way you know you are getting clean power straight from the source. That way you don't fry your stock harness
Old Oct 20, 2006 | 11:12 AM
drj73099's Avatar
Well, the stock harness works because when I ran out of time and needed that headlight I put the old bulb back in and it still works like a charm.
Old Oct 20, 2006 | 11:56 AM
well stock harness' work bu HID's require jmore wattage than those harness' were designed to provide.
Old Oct 20, 2006 | 11:57 AM
is this just bulbs???? or bulbs and ballasts?
aznlaoboi315
Lighting
Feb 29, 2008 07:07 PM
racebum
Jan 3, 2008 08:23 PM
TegoDC5
Jul 27, 2005 05:19 PM
Jim80y
May 15, 2003 06:19 PM
Vtec195hpR
Jan 18, 2003 02:43 PM
