Dyno'd again
Old Oct 22, 2006 | 12:52 PM
98vtec's Avatar
moderator emeritus
Default Dyno'd again
First dyno tune a couple months ago
yesterdays dyno at Velocity Trends
now......this is a good example of different dyno's reading different even while still being the same brand.
I also tested the BPi flowstack. When I get the complete file with all my dyno runs, i will post a thread on it. There was absolutely no tuning for the test. I did the comparison on my first three runs. 1st without flowstack or filter, 2nd with stack, 3rd with stack and filter. To my suprise i actually gained after putting the filter on. My midrange really picked up with it, but i'll post those when i get them.
I havent had a good look at the graphs yet, but it was worth the 50 bux, IMO
Old Oct 22, 2006 | 12:59 PM
InvaderTrax's Avatar
Should have done one with a regular filter too
Old Oct 22, 2006 | 01:35 PM
98vtec's Avatar
moderator emeritus
Default Re: (InvaderTrax)
i didnt have one. lol
Old Oct 22, 2006 | 01:40 PM
GraphiteMW's Avatar
Sounds like I am gonna be placing a order for a flowstack soon :D
Old Oct 22, 2006 | 02:07 PM
SteveoBA8's Avatar
Default Re: (GraphiteMW)
Old Oct 22, 2006 | 02:27 PM
PrecisionH23a's Avatar
Default Re: Dyno'd again (98vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98vtec &raquo;</TD></TR><TR><TD CLASS="quote">now......this is a good example of different dyno's reading different even while still being the same brand.
On the higher horsepower chart you are running a bit leaner than you are on the lower chart which accounts for a bit more power. Either way, I would add some more fuel... it's a bit lean to my liking. I don't know what the weather is like in Fl right now... but here it's a good bit cooler which def helps to make more power compared to 20deg higher a few months ago.
But yes, dyno's do read differently. DynoJet's though in my opinion can give you good repeatability for comparison.
Old Oct 22, 2006 | 02:33 PM
98vtec's Avatar
moderator emeritus
Default Re: Dyno'd again (PrecisionH23a)
well, the way i figure is that i dont really like the sniffer widebands and they tend to output a leaner mixture than what it really is. I would have been able to use my wideaband if my connector would have came in
I'll be able to post better info once i get the complete file.
Old Oct 22, 2006 | 02:34 PM
skunked's Avatar
keep in mind you're comparing STD and SAE #'s as well.
Old Oct 22, 2006 | 02:36 PM
98vtec's Avatar
moderator emeritus
Default Re: Dyno'd again (skunked)
true, but the numbers and correction factors are the least of my worry.
Old Oct 22, 2006 | 02:43 PM
DOHCVTEC190's Avatar
good point on the correction factors...using SAE would probably bring the number down some.
nice gain on the flowstack. i need to jump on the dyno with mine. i have the flowstack and filter installed with my AEM CAI tubing. So...it's still set up as a cold air. Maybe after Christmas time. I have S100 in a box just waiting to go to hondahaven to get it tuned.
Old Oct 22, 2006 | 02:44 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98vtec &raquo;</TD></TR><TR><TD CLASS="quote">well, the way i figure is that i dont really like the sniffer widebands and they tend to output a leaner mixture than what it really is. I would have been able to use my wideaband if my connector would have came in
I'll be able to post better info once i get the complete file.</TD></TR></TABLE>
Good point... typically I've seen about a .3-.5 diff on dyno-jet sniffers.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skunked &raquo;</TD></TR><TR><TD CLASS="quote">keep in mind you're comparing STD and SAE #'s as well.
Bingo. I didn't even see that, lol.
Old Oct 22, 2006 | 02:54 PM
crdcz03's Avatar
Fortune Cookie Member
ill send you the doctor bills for making my ears bleed Blake
you're just lucky they fixed teh dyno
Old Oct 22, 2006 | 03:22 PM
Lude@Heart's Avatar
haha behold, the Dyno Killer!!!
Old Oct 22, 2006 | 05:14 PM
98vtec's Avatar
moderator emeritus
Default Re: (crdcz03)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crdcz03 &raquo;</TD></TR><TR><TD CLASS="quote">ill send you the doctor bills for making my ears bleed Blake
you're just lucky they fixed teh dyno </TD></TR></TABLE>
hahahahaha
Old Oct 22, 2006 | 05:24 PM
crdcz03's Avatar
Default Re: (98vtec)
hahahahaha
Old Oct 22, 2006 | 05:36 PM
se93's Avatar
Blake:
Get the full data to see what the gains are. I am curious to know. Hey, do you know if its better to dyno the BFI unit as a cold air intake or a short air intake?
Old Oct 22, 2006 | 05:45 PM
98vtec's Avatar
moderator emeritus
Default Re: (se93)
i really dont know, thats something that bryan could likely answer tho.
Old Oct 22, 2006 | 06:56 PM
98vtec's Avatar
moderator emeritus
i think my exhaust and throttle body are holding me back a little bit, but it makes great power and holds the torque pretty well. I'm happy with the way the car performs.
now i just gotta fix my shift cables
Old Oct 22, 2006 | 07:58 PM
98vtec's Avatar
moderator emeritus
video:
http://www.youtube.com/watch?v=TE9cX0gs94M
Old Oct 22, 2006 | 08:02 PM
mgags7's Avatar
Default Re: (se93)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by se93 &raquo;</TD></TR><TR><TD CLASS="quote">Blake:
Get the full data to see what the gains are. I am curious to know. Hey, do you know if its better to dyno the BFI unit as a cold air intake or a short air intake?</TD></TR></TABLE>
colder air is always better
a longer pipe is going to move the powerband up
its up to your preference
Old Oct 22, 2006 | 08:06 PM
SMSP's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98vtec &raquo;</TD></TR><TR><TD CLASS="quote">true, but the numbers and correction factors are the least of my worry. </TD></TR></TABLE>
Well your latest graph is at a CF = 1.02
Try to get both run files and then you can compare at the same correction.
Your scales are different too so that makes it even harder to compare.
But the main difference I see is looking at the 4k and 7.5k torque values. With your first run torque at 7.5k &lt; 4k, on the second graph torque at 7.5K = 4k so your top end is better now. Flow stack? cooler air? Don't know but it's better.
Old Oct 22, 2006 | 08:08 PM
K-Spec's Avatar
did you tune with an open header?
Old Oct 22, 2006 | 08:13 PM
98vtec's Avatar
moderator emeritus
Default Re: (khalal538)
axle back of the N1 removed
Old Oct 22, 2006 | 08:15 PM
K-Spec's Avatar
is it better to tune it with an open header or full exhaust? and any reason for taking it off at the axleback?
Old Oct 22, 2006 | 08:17 PM
98vtec's Avatar
moderator emeritus
Default Re: Dyno'd again (SMSP)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SMSP &raquo;</TD></TR><TR><TD CLASS="quote">Well your latest graph is at a CF = 1.02
But the main difference I see is looking at the 4k and 7.5k torque values. With your first run torque at 7.5k &lt; 4k, on the second graph torque at 7.5K = 4k so your top end is better now. Flow stack? cooler air? Don't know but it's better.</TD></TR></TABLE>
could be a combination of both, but yea whenever i get the file i'll be able to get the correction right. i have the file for the previous dyno, so i could just set it to my current dyno....
