Dump Pipe Or No Dump Pipe...
Old Oct 17, 2006 | 06:37 PM
AccludePower's Avatar
Default Dump Pipe Or No Dump Pipe...
I tryed to figure this out on my own but couldnt, so ill need some feedback, Ok, i have a boosted h22 and the wastegate is on the right side of my manifold which causeing the location for the dump pipe to face my alternator. (Ramhorn Design Manifold) I havent had time to install a dump pipe yet so ive been driving it the way it is, but everytime i hit boost all of that hot air is going into the alternator and causeing my batt light to flick on and off. I was looking arround and found that there are block off flanges that give the option of not using a dump pipe at all. Does it depend on the turbo weather someone should use the pipe or not?
Modified by AccludePower at 10:01 AM 10/19/2006
Old Oct 17, 2006 | 06:44 PM
BlUAc's Avatar
Default Re: Dump Pipe Or No Dump Pipe... (AccludePower)
well does your turbo have an internal waste gate or no if not a dump pipe is of utmost importance you will melt something in your engine bay probably your alt first since it is hitting it first then id say your valve cover will be next if not first
Old Oct 17, 2006 | 07:37 PM
championshipwhite93si's Avatar
Default Re: Dump Pipe Or No Dump Pipe... (BlUAc)
just get a piece of exhaust piping bent to where it dumps under the car and out of the way of anything, if all else fails, route it to the down pipe and be done with it.
Old Oct 17, 2006 | 08:56 PM
Hawkze_2.3's Avatar
Damn dude, you're loosing major hp from sucking back in your exhaust gases and I'm sure that's very bad for your alternator. Definately get a dump tube!!
If you're asking whether or not you need a wasteagte then you don't need to drive a boosted car. Do you realize what a wastegate does?? Without it you will boost uncontrollably and your engine probably won't last very long...
Old Oct 17, 2006 | 09:01 PM
A Blue Lude's Avatar
Default Re: Dump Pipe Or No Dump Pipe... (Hawkze_2.3)
Heh, a wastegate blockoff plate
Old Oct 17, 2006 | 09:51 PM
Speedra500's Avatar
Default Re: Dump Pipe Or No Dump Pipe... (A Blue Lude)
some drag cars use them...
Old Oct 18, 2006 | 04:37 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hawkze_2.3 &raquo;</TD></TR><TR><TD CLASS="quote">Damn dude, you're loosing major hp from sucking back in your exhaust gases and I'm sure that's very bad for your alternator. Definately get a dump tube!!
If you're asking whether or not you need a wasteagte then you don't need to drive a boosted car. Do you realize what a wastegate does?? Without it you will boost uncontrollably and your engine probably won't last very long...</TD></TR></TABLE> Dude i know what a wastegate is im not stupid. you fail to realize that there are other people that block the pipe off, the only thing i wanted to know is what kind of turbo could be used. as for the importance of the wastegate mine has an 11lb spring and my car is running 11lbs of boost. Im not new to boost im just curious about this cause ive never seen a turbo kit without a dump pipe.
Old Oct 18, 2006 | 04:42 AM
I figured out what ill have to do about the pipe since there is very lil room between the wastegate and the alternator. thanks to everyone that put in there opinion on this subject.
Old Oct 18, 2006 | 04:44 AM
Mykizism's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AccludePower &raquo;</TD></TR><TR><TD CLASS="quote"> Dude i know what a wastegate is im not stupid. you fail to realize that there are other people that block the pipe off, the only thing i wanted to know is what kind of turbo could be used. as for the importance of the wastegate mine has an 11lb spring and my car is running 11lbs of boost. Im not new to boost im just curious about this cause ive never seen a turbo kit without a dump pipe.</TD></TR></TABLE>
after reading your first post, its apparent you dont know what you are talking about.... go ahead and block off that wastegate and then boost.. see what happens
Old Oct 18, 2006 | 04:55 PM
Default Re: Dump Pipe Or No Dump Pipe... (Mykizism)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mykizism &raquo;</TD></TR><TR><TD CLASS="quote">
after reading your first post, its apparent you dont know what you are talking about.... go ahead and block off that wastegate and then boost.. see what happens </TD></TR></TABLE>ok then, i guess your right, i dont know anything at all. i guess i just have a 397hp fully built motor by luck. thanks for the feedback KIZISM. lol p.s. i never said i WAS going to block it off, i wanted to know why they make a flange to block it off. you have yourself a great night now bro...
Old Oct 18, 2006 | 05:47 PM
md23vtec's Avatar
get the dumptube
Old Oct 19, 2006 | 06:57 AM
Dangger's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AccludePower &raquo;</TD></TR><TR><TD CLASS="quote">p.s. i never said i WAS going to block it off, i wanted to know why they make a flange to block it off. </TD></TR></TABLE>
If one was to use a block off plate, that means they won't be using an external wastegate. You still need some sort of way to regulate the exhaust gases in order to control boost. So one can assume you ONLY use a wastegate port block off plate because you're using an INTERNAL wastegate that's attached to the turbo.
there no sense is gloating your high powered car and still not understand what to do with your dumptube and asking trivial stuff about wastegate blocking plates.
Old Oct 19, 2006 | 08:54 AM
Default Re: Dump Pipe Or No Dump Pipe... (Dangger)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dangger &raquo;</TD></TR><TR><TD CLASS="quote">
there no sense is gloating your high powered car and still not understand what to do with your dumptube and asking trivial stuff about wastegate blocking plates.</TD></TR></TABLE>im sorry i misinformed you all about my intentions, i already had the dump pipe i just havnt had time to install it yet due to an acward location my wastgate is in, while looking for the flange i came accross a block off flange and the only thing i wanted to know is WHY there is one available. i NEVER intended on blocking mine off at all. when i asked if it depended on the turbo weather i should use the pipe or not i DID NOT mean me personaly i meant in general, instead of putting: (weather i should use the pipe or not) i should have put: (weather someone should use the pipe or not) Sorry i am a sloppy writer, Hope everyone understands what i wanted to know now, thanks...
stillsmokey
Dec 28, 2007 12:37 PM
DB1_559
Sep 21, 2005 07:33 PM
B16CRXT
Mar 14, 2005 02:34 PM
Teg4e
May 29, 2002 10:41 AM
