Finally DYNOED JDM H22 hatch...it's been a long time comming!
Re: Finally DYNOED JDM H22 hatch...it's been a long time comming! (NICEHATCH)
Nice, I like the fact that you kept the stock pistons, cams, fuel pump, injectors, and made 201whp. That's very impressive. I'll have to write all that down.
Re: Finally DYNOED JDM H22 hatch...it's been a long time comming! (MadCityLude)
that makes me feel good bout my motor going in soon lol good job man
awesome results...
what you u think u would have made with that header and w/o the msd ignition? also theres the perfect example of where the h22 stops making power
moderator emeritus
Re: Finally DYNOED JDM H22 hatch...it's been a long time comming! (95hprelude)
did you stop revving at 7000 or what? Kinda weird that the power drops off so soon....
how long did it take to tune? and where did you have it tuned?
what size exhaust after the an-r?
Re: (mixxxwell)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mixxxwell »</TD></TR><TR><TD CLASS="quote">did you run balancer shafts?</TD></TR></TABLE>
No I had the balancer shafts removed. As well as the EGR Removed and Placed a Block-Off Plate.
moderator emeritus
Re: Finally DYNOED JDM H22 hatch...it's been a long time comming! (98vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98vtec »</TD></TR><TR><TD CLASS="quote">did you stop revving at 7000 or what? Kinda weird that the power drops off so soon....</TD></TR></TABLE>
Re: Finally DYNOED JDM H22 hatch...it's been a long time comming! (spun311)
Noticed you are running a p28..what intake manifold are you using? What is the program on the p28? Nice numbers
moderator emeritus
Re: Finally DYNOED JDM H22 hatch...it's been a long time comming! (Halo)
Chrome Tuned P28/vtec crossover at 4800rpm
*Crome
i would guess its the stock manifold with the IAB's disabled or removed.
*Crome
what about the lower plenum?
is it gutted or did you kept the lower manifold stock?
did you cut the butterflies out or just unbolt the indivual plates?
moderator emeritus
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NICEHATCH »</TD></TR><TR><TD CLASS="quote">Yep...butterflies are removed however the plate was kept to increase plenum size. </TD></TR></TABLE>
thats what i did. The IAB shaft and all is still in there. Taking the valves out was alot easier than removing everything and welding the holes shut.
Here's my graph. Very similar setup.
My hp doesnt start to drop off til around 7300 and my torque is a slow drop off.
and i just noticed that your numbers arent SAE corrected. I'm not downing your car at all. Your graph looks pretty damn good. Looks like you could make a little more midrange power with some more fine tuning. Its just kinda awkward to me that your power drops off pretty steep after 7000.
Do you happen to have your bin file on hand? I wouldnt mind seeing your map. I'll let you see mine
IM me and we'll trade email addresses.
