Brake Light problem
Old Oct 19, 2006 | 04:36 PM
Blk_Lude98's Avatar
Default Brake Light problem
My brake light flickers on and off. When the weather is warm, the light does not flicker on and off as much. However, when its cold, the light seems to consistently stay on. It also comes on when I brake really hard as well. Does this light have to do specifically with Emergency Brake? Or does the Brake Light have to deal with the normal brakes as well. Any information would be helpful
Old Oct 19, 2006 | 09:48 PM
Siegfried's Avatar
Default Re: Brake Light problem (Blk_Lude98)
It depends of both and also of the brake fluid level and bulbs.
Check if your fluid is good & all your bulbs.
If it's none of those then check a service manual how to check the brake sensors on both rear lights, if it doesn' t come from these than maybe your fuel gauge/temp panel doesn' t work correctly.
Old Oct 20, 2006 | 06:23 AM
TurbodTegSfaria's Avatar
Default Re: Brake Light problem (Siegfried)
that brake lamp on the dash is either e brake switch or fluid switch.. try unplugging the cap on the fluid.. then if it still happens thenyou might have to pull your console out to check the e brake switch,, it could have a coin or somthing that can be shorting it
Acura Tech
Old Oct 20, 2006 | 07:27 AM
92SleeperH23's Avatar
Default Re: Brake Light problem (TurbodTegSfaria)
The same thing happened to me last year, my fluid was just a little low
dderolph
Jan 10, 2013 12:34 PM
hatch96y7
Oct 26, 2007 08:08 AM
kolohekine
10
Jan 27, 2005 04:44 PM
01SilverGSR
Dec 29, 2002 11:59 AM
hybridbmw
Feb 19, 2002 10:38 AM
