To jack or not to jack?
Old Oct 22, 2006 | 06:57 PM
ludekid4323's Avatar
Default To jack or not to jack?
I just ordered a Tanabe rear upper strut tower bar off of hopupracing.com
I just wanted to know if I should jack up the car when installing it? I have heard many different oppinions on doing this even though its probably not that complicated
Old Oct 22, 2006 | 07:30 PM
avallach's Avatar
Default Re: To jack or not to jack? (ludekid4323)
Tanabe itself recommends that you offload your suspension when installing the upper tie bars. Install the bar with the car unjacked. When you're ready to apply the proper torque settings to the bar, raise it.
Old Oct 22, 2006 | 07:35 PM
GRAF-FITI's Avatar
* B A N N E D *
Default Re: To jack or not to jack? (avallach)
agreed
Old Oct 22, 2006 | 07:39 PM
Default Re: To jack or not to jack? (GRAF-FITI)
Ok cool thanks
Old Oct 22, 2006 | 10:22 PM
russlan44's Avatar
i had almost the same questions ill be installing upper front, upper back and lower back strut bars and ppl say different stuff about jacking up car the car. so if anyone can tell me what to do that will be helpful. and like someone sayed at the top install it and when you going to tighten the bolts jack up the car is it right?
Old Oct 23, 2006 | 05:51 AM
E-Money's Avatar
Default Re: To jack or not to jack? (russlan44)
i guess it would not be the same principal of installing a rear sway bar? Jacking the car up on LCAs then install, then torque?
Old Oct 23, 2006 | 07:15 AM
Hawkze_2.3's Avatar
Default Re: To jack or not to jack? (E-Money)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by E-Money &raquo;</TD></TR><TR><TD CLASS="quote">i guess it would not be the same principal of installing a rear sway bar? Jacking the car up on LCAs then install, then torque?</TD></TR></TABLE>
A swaybar has free-moving joints....it doesn't matter how you install a swaybar it will settle in however it wants on its own.
obuhmyuh
Nov 21, 2007 08:46 PM
SiCkSrV
May 24, 2003 11:47 AM
Understeer
Oct 24, 2002 10:43 PM
Comptech98GSR
May 23, 2002 01:45 AM
tEK_99
14
Dec 20, 2001 09:30 AM
