Help, check engine light.
Old Mar 19, 2007 | 07:11 PM
JBirch_97Prelude's Avatar
Default Help, check engine light.
I just had a H22A swapped in, in placed of a H22A. After I test drive care ran fine, and no signs of trouble. Once I got on the road again I got a check engine light. So I drove it back to the shop and they checked the code and it said there was a misfire in cylinder 1. The car was driving fine. We reset the ECU and I went on my marry way. I even tried to get it inspected but the ECU said it was not finished cycling. As soon as I lefted the inspection station, I got a check engine light again. The car is driving fine.
Old Mar 19, 2007 | 07:15 PM
1GPlusSH's Avatar
Default Re: Help, check engine light. (JBirch_97Prelude)
I'd check your wires, distributor, and plugs.
Old Mar 19, 2007 | 07:21 PM
Default Re: Help, check engine light. (1GPlusSH)
The car is still OBD2, the crank sensor is routed threw the Distributors TDC sensor. The engine was purchased from H-Motorsonline. They usually deliver good parts.
Stephen122193
Jan 2, 2012 02:45 PM
bigodub93
20
May 19, 2010 01:49 PM
sky9
Dec 16, 2009 08:54 PM
Preludes'R'Us
Aug 22, 2007 02:11 PM
